If the whole system is cutting out I don't think it would be an amp. If an amp goes bad it should just affect that one speaker. It's probably in the head unit or the receiver unit inside the dash.
Check out doctordons.com and give them a call. They should be able to tell you what the probable cause is, and they can rebuild any of the components to work like new and provide a warranty.
