Sponsored by: Innova
Kenwood Navigation
Old Aug 9, 2005 | 03:47 PM
waymirec's Avatar
waymirec
Default Kenwood Navigation
Does anyone here have a Kenwood Navigation system? I've got a KNA-DV4100 that for some reason refuses to enter into route guidance. I can enter a destination and then have it run through a demo or trail run to the destination and all the route guidance features work, but once I tell route guidance to start it gives the audible message saying to procede to the highlited route and then route guidance will start, yet it never does start. The features for route guidance (such as the turn notifications) never activate. After having absolutely no luck finding any support any where else i'm hoping someone on here might have a suggestion or two. Thanks.
-- Chris
Old Aug 9, 2005 | 05:51 PM
Red-C6's Avatar
Red-C6
Default Navigation Problem
The Eclipse navigation unit I just installed had EXACTLY the same symptoms until I hooked up the Vehicle Speed Sense (VSS) wire. The Eclipse has a diagnostic screen that lets you check to see if the VSS wire is being recognized. Does the Kenwood have something similar?
