Sponsored by: Innova
Do I need a higher amp alternator?
Old Aug 19, 2005 | 09:36 AM
hz900's Avatar
hz900
Default Do I need a higher amp alternator?
I need a new alternator and am about to put in two amps in my car. First is a Pioneer 760 watt amp and the second is a Pioneer 200 watt amp. I was thinking the stocker would do, but I wanted to check to make sure, if I don't need it I'm not going to spend the extra money just because.
I have a '90 model and the stock alt. is 105 amps.
Old Aug 19, 2005 | 11:22 AM
Steve Germany's Avatar
Steve Germany
You did not provide much information but the short answer is no - not now. After you have it set up and power presents a problem then readdress the issue.
Old Aug 19, 2005 | 11:34 AM
Metal Wulf's Avatar
Metal Wulf
no alt needed, but I would do the big 3.
Old Aug 19, 2005 | 01:33 PM
knewblewkorvette's Avatar
knewblewkorvette
Old Aug 24, 2005 | 11:44 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
How many amps is a stock 02 alternator?
To Do I need a higher amp alternator?
