Sponsored by: Innova
SYS Flash in LCD
Old Aug 31, 2005 | 05:47 PM
RFDrpm's Avatar
RFDrpm
Default SYS Flash in LCD
Has anyone done the 1k ohm 1/2 watt resistor instal to cure this problem. If so a little advice please.
Old Aug 31, 2005 | 06:08 PM
ILOVEVETTES05's Avatar
ILOVEVETTES05
What are you talking about? Does the D.I.C. say something when you install an aftermarket headunit? If so, I also need to know. I'm about to do an install.
Old Aug 31, 2005 | 06:46 PM
scott_fx's Avatar
scott_fx
i think he has a c4, i'm guessing it's a '92 and red
Old Aug 31, 2005 | 09:52 PM
vettenet's Avatar
vettenet
I'm getting the same code flashing in my DIC (94 coupe) after hooking up an aftermarket stereo too. I recall seeing the fix that you are talking about, but I haven't heard anything about results. I remember thinking that it didn't affect my year, but the evidence would suggest otherwise. I'll be interested to know the results.
Old Sep 1, 2005 | 09:45 AM
RFDrpm's Avatar
RFDrpm
Yeah, SYS flashes in the DIC. So, since Im an electronics tech I should be able to figure this out. Shes going up on jackstands this weekend for new exhaust, headers, and all around tune up. While Im in there I will play with this resistor install. Ill keep y'all updated.
To SYS Flash in LCD
