I am looking for some sort of 12 volt power supply to run my stereo and monitors off of at the big indoor shows. Does anyone know what I would use and where to get one? I have seen at some other shows where guys have a power supply running there systems.
Have to make sure you match the amperage. Also alot of cheap inverters will add noise into the system. I use one of the SPS80 's for my car and have a permanet terminal block mounted to the car for it. I just plug it into the wall and the car...all done. Also you might want to wire in a toggle switch to turn on all your electronics while the key is in the off position.
