Sponsored by: Innova
System cut out
Old Oct 7, 2005 | 12:33 PM
KDuniverse's Avatar
KDuniverse
Default System cut out
Last night on my way home, I had the music turned up a little more than usual, and twice the system cut out. The whole thing, highs, lows, everything lowered, then came back.
What are the things I should check? Also, Eatrice, I still never did that big 3 or whatever you call it. I want to though. Can you give me some info on it again?
Old Oct 7, 2005 | 02:42 PM
BRICHC4's Avatar
BRICHC4
The only times I've had things cut out was either something was loose behind the HU, I blew a fuse or blew the speakers, I don't know what your problem is but my guess is it sounds like a power issue and the system is either running out it, or guarding itself from too much
Old Oct 12, 2005 | 04:53 PM
KDuniverse's Avatar
KDuniverse
TTT. still going on. i checked all the connections at the amps, and they seem fine.
Old Oct 12, 2005 | 07:15 PM
scott_fx's Avatar
scott_fx
when did it cut out? during a strong bass 'hit'
Old Oct 12, 2005 | 08:02 PM
KDuniverse's Avatar
KDuniverse
no, it cuts out at all different times.
Old Oct 14, 2005 | 10:28 PM
1982CorvetteDude's Avatar
1982CorvetteDude
What are the specs on the stereo? Type of Head Unit, Amps, Subwoofers, and other speakers. Specs on the woofers ( 2, 4 , 8 ohm and how are they connected to the amp? Bridged or stereo)
1. Everything cuts out in together? Volume wise? It's not just the subwoofers?
2. It just lowers in volume, not cut completly out? For how long?
3.Where are your amps grounded?
4. How is your amp remote wire hooked up? To the radio or ignition switched?
5. Does your head unit flicker when it cuts out?
Old Oct 14, 2005 | 11:28 PM
Kale's Avatar
Kale
actually what he's looking for when he says big three is this:
Battery Neg - Chassis
Alternator - Battery Positive
engine to Chassis
first thing i'd look at is the power connections to your amp.
Old Oct 16, 2005 | 09:25 AM
KDuniverse's Avatar
KDuniverse
what it seems to be happening is the amps are shutting on and off. the actual music never cuts out, but lowers so much, you can hardly hear it. I have to check the fuses. thanks kale for that. I want to do that anyway.
To System cut out
