Recommendations for Amps (c5)
Back when I was really into this JL was stamped steel crap and no one with any sense ran it
Apparently this has all changed. I am looking for recommendations on amp brands with CLEAN power .... SQ is very important. My current system runs two Xtant amps but the bass is a bit underpowered at 300 watts. I know that a seperate bass amp is always preferred but like I said I really need to maxamize space. I also plan on having a divider in the car. I am a golf pro by trade so I need room for the sticks
Thanks in advance
Fej
Fej
Hope you are not on dial up. Lots of pictures.
I've used Xtant, McIntosh, PPI (before sell out), HiFonics (before sell out) and decided to replace my old PPI, she's gettin' tired and my buddy used her for 2 yrs in a wet trunk!
I helped another Forum member do an install on his AE Vert and he used the JL 300/4 and 500/1.
I was quite impressed with the power they made and drove his Diamond components very cleanly.
I went out the next day and bought the 300/4 (~$450 at Tweeter) to put on my Focal Utopias and it sounds very good.
I've heard cleaner amps, but for well over twice the price. The difference is negligible to me.
For a picky audio curmudgeon, I'm real happy with the JL's.
This amp is also very efficient and flexible for multifple applications.
They put out claimed power with voltage as low as 11 volts!
THD at Rated Power < .03% @ 4 ohm/channel (20Hz - 20 kHz)
Signal to Noise >108dB !
Damping Factor >200 @4ohm/channel (not spectacular, but respectable)
I'm not a rep for these cats, just impressed to see something decent come out amidst all the crappy, garbage that caters to the mindless boombox generation that has no concept of true reproduction.
Scott
Fej
Good choice on the speakers. I have heard nothing but great things about Dyn Audio.
I'm running 2 Xtants on Focals and an Earthquake sub and am happy with the set up.
