help removing door speakers
Here's the deal with those pain in the *** B(l)ose boxes ..
You need to completely un bolt the inner door skin .. Lots of 7 and 10 mil bolts
The " box" might be glued in .. might have to pry on it alil ..
After that ... then CAREFULLY - slide out the "box" . It will be a pain in the ****.. but it will come out ..you might have to loosen the window track too ..
It will come out by pulling it away from the hinge side .
I just did one of these - Never gets easier .. but - it is possible ..
Good Luk..
