Sponsored by: Innova
vss wire?
Old Nov 3, 2005 | 12:12 AM
PolishDude's Avatar
PolishDude
Default vss wire?
where is it located, i saw something about it being behind the knee panel, are they refering to the interior part that is under the steering wheel? Is it a green wire with a white stripe or a white wire with a green stripe? And there are two and I just have to hope that i get the right one, is this all correct? thanks
Old Nov 3, 2005 | 09:21 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Hope this helps...
After some, disassemble of the dash of course with the service Manual in hand! I found the right green/white wire. It goes to the plug on the back of the instrument cluster. Actually there are two green/whites, one is for the Oil Temp the other is the speed sensor wire.
After unplugging the connector from the cluster you will find two green/white stripe wires, you will want the Green/white (A7-circuit 817) with a Tan/white (A6-circuit 33) above it and a black (A8-circuit 150 ) below it..The other green/white (A10-circuit 357) oil temp has a blank and a gray on each side.
pin..wire
A5 Blank….
A6…Tan/White
A7 Speed Sensor…Green/White
A8…Black
A9 Blank
A10 Oil Temp…Green/White
A11…Gray
http://www.vetteessentials.com/inst...ezel_howto.html
Step 9c shows the plug...I did not have to remove the cluster to reach it just pull it forward
