Sponsored by: Innova
AVIC Hideaway Mount HELP!
Old Nov 16, 2005 | 09:03 PM
goof2cbr's Avatar
goof2cbr
Default AVIC Hideaway Mount HELP!
Hi Guys and Gals
My AVIC N2 will arrive this Fri and I'm very excited.
I have relocated my A/C climate controls to the ashtray area, leaving alots of room for the display unit.
My problem is the hideaway mounting.
I would like to mount it in the huge space behind/under the glovebox. Right above the pass floor lamp. But it doesn't have any supports to mount to, nothing easy or obvious to me. Any suggestions? Pics would really help. thanks
PHIL
Old Nov 16, 2005 | 11:40 PM
Glex's Avatar
Glex
Mine is in that same spot. It sits ontop of the large wire bundle that runs perpendicular to the glove box. It seems fine as it is a fairly tight fit. Nothing else is holding it in place.
Old Nov 17, 2005 | 03:07 AM
goof2cbr's Avatar
goof2cbr
So your hide away unit is (I assume tie strapped) to the large wire bundle?
Old Nov 17, 2005 | 10:55 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Did the same but used some large tie wraps to the dash frame.
Old Nov 17, 2005 | 11:45 AM
Glex's Avatar
Glex
I was in and out of that area so much I stopped the tie wraps. When the panel is put back in place, it doesn't move around. (call me lazy!) One of these days I'll strap it down again.
I have a question though for anyone with an N1....... My AM radio is inop. FM is fine. Antenna is hooked up. Have tried to reset with no luck. Any thoughts?
Old Nov 23, 2005 | 06:01 PM
DeeGee's Avatar
DeeGee
I actually mounted mine inside the glove box.
It has to sit level and square. There are shoulders in there that do the job. I never used the glovebox for anything anyway
Old Nov 28, 2005 | 08:40 PM
goof2cbr's Avatar
goof2cbr
INSIDE the Glove Box!?
Got any pics? I just might put my hideaway there...
Much appreicated!
Old Nov 28, 2005 | 08:58 PM
techguy's Avatar
techguy
ok -- im assumming that we are talking about the C5 ..
Soo that being the case ..
There is plenty of room on the side of the Tourqe tube tunnel .. pass side..
Ive done the brains for other units there ... fits right behind the carpet next to that lil vent there
Good luk
Old Dec 3, 2005 | 06:58 PM
DeeGee's Avatar
DeeGee
Much appreicated!
Sorry it took so long.
The box just sits on the shoulders. Not particularly pretty but when the glovebox is closed it doesn't move and it sits flat and square which is what's needed.
To AVIC Hideaway Mount HELP!
