Viper Alarm
Old 12-19-2005, 09:42 AM
KDuniverse
KDuniverse's Avatar
Default Viper Alarm
My car is at the body shop. They can't seem to be able to start the car now, but it has started there. How can I make sure the alarm is not the problem? Of course, no one touched a thing...
Old 12-19-2005, 10:46 PM
screw991le
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The DEI alarm is just pluged in, just unplug it and re attach the harness.
Old 12-20-2005, 01:44 PM
KDuniverse
KDuniverse's Avatar
unplug what harness? The main with all the power and ignition?
Old 12-21-2005, 04:32 PM
KDuniverse
KDuniverse's Avatar
TTT. anyone else with Viper alarms?? Viper 791xv to be exact. I need to make sure the alarm is not cutting off the ignition some how. I have fuel, no spark. Just need to make sure the alarm is not the issue.
Old 12-30-2005, 02:22 AM
0Audio Dave
Former Vendor
Audio Dave's Avatar
Location: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
We sell the Viper 791... if you unplug the main power plug on the brain, it is white and has about 10 wires in it, the starter kill should be disengaged. The starter kill is wired in the relay pack of the remote start. The starter wire will be cut, and the purple wire from the remote start will be going towards the starter, and the green wire towards the key switch. You can cut these and reconnect the starter wire, and all should work fine... If not, call me at work at 615-217-2819 on Friday between 9am and 6pm CST, and ask for Dave Hale... I will help you out in any way I can!!
Hope this helps, and you can contact me via my website and forums located below in my signature if you need anything else...
To Viper Alarm
Quick Reply: Viper Alarm
