Sponsored by: Innova
Back-up wire hook up for Avic?
Old Dec 22, 2005 | 10:43 PM
rcs128's Avatar
rcs128
Default Back-up wire hook up for Avic?
Hey, quick question for all you guys that have installed an Avic in a C5... where did you tap into the wire for the reverse sensor wire?
Thanks... I'll be twisting myself around under the dash tomorrow. Hopefully by dinnertime the Advil and the Avic will be working!
Old Dec 24, 2005 | 02:59 PM
LV_2_XLR8's Avatar
LV_2_XLR8
Since I was putting a backup camera in my third brake light, (thanks to GB Vette for the great instructions) I had already drilled a hole accessing the rear fascia from the cabin. I tapped into my backup light wire right at the bulb, behind the rear fascia. I had the carpet and trim pieces already off to install a 12 CD changer and it seemed like the easiest way, since everything was aleady torn up.
Don't forget top post pics of your finished install.
Old Dec 25, 2005 | 11:12 AM
rcs128's Avatar
rcs128
Thanks! I'll be sure to get the pics up when I'm done... but I'm taking my time with the console, so it may be a while...
Old Dec 27, 2005 | 11:22 AM
DeeGee's Avatar
DeeGee
Me too. I ran a wire round through the cockpit, over the door pillar and into the trunk. I drilled a hole in the bulkhead to route the wire. I then tapped into the reversing light circuit at the number plate/reversing light fitting.
To Back-up wire hook up for Avic?
