Sponsored by: Innova
Rear speaker replacement
Old Dec 30, 2005 | 02:20 AM
Corvettetodd's Avatar
Corvettetodd
Default Rear speaker replacement
Is there a thread pertaining to the removal of the rear speaker panels to replace the rear speakers on a C5 coupe. It looks like there are clips holding them in, but I dont want to break anything.
Also has anyone built their own stealth sub box to fit under the rear panel. I plan on building one this weekend with one 10" sub and any tips would be apprieciated....
Old Dec 30, 2005 | 03:13 AM
scott_fx's Avatar
scott_fx
not sure about removing the rear speakers, but drive around a while with the h/u faded all the way to the front. you may find out that you like the way it sounds better. This brings the sound stage front and center where it should be fyi: Most sq winning vehicles dont have rear speakers
as far as the stealth box most of us have them. i have a set of plans for making your own or you can check out www.subthump.com and save yourself the headache of making your own (when you factor in supplies and oem carpeting you wont save much money making the box on your own)
also, i see you're a junior member. check out the c5aaudio faq :edit: seems like you did check out the faq
