Sponsored by: Innova
Install Tweeters
Old Aug 3, 2001 | 03:48 PM
Turbo5's Avatar
Turbo5
Default Install Tweeters
Is there any way to install a tweeter in the Bose system without having to rewire the entire stereo? I would like to splice two in on the existing speakers. I have been considering adding a couple in the front doors if possible. If not, I am pretty happy with the unit as it came stock.
Turbo5 :bigears
'99 Black on Black Coupe
[Modified by Turbo5, 1:49 PM 8/3/2001]
Old Aug 3, 2001 | 04:36 PM
99HT's Avatar
99HT
Default Re: Install Tweeters (Turbo5)
Just put them in parallel with the 3.5" Bose twiddlers. Use at least a simple cap crossover. You can also tap these wires on the back of the head unit.
Old Aug 4, 2001 | 09:40 PM
Turbo5's Avatar
Turbo5
Default Re: Install Tweeters (99HT)
Thanks 99HT. Can you explain cap crossover? What is that?
Turbo5
'99 Black on Black Coupe ;)
Old Aug 4, 2001 | 10:21 PM
99HT's Avatar
99HT
Most tweeters if bought in a "kit" come with some type of crossover network. For a tweeter, you need a high pass filter type of crossover. You do not want low frequency signals to get to the tweeter and cause distortion. A capacitor of a specific value, makes a simple crossover network for a tweeter. The capacitor will come with the tweeter kit.
More expensive tweeters come with a more complicated crossover network consisiting of inductors, capacitors and sometime resistors.
Since the C5 amps driving the Bose Twiddlers is only about 18 wrms/ch, you do not need expensive high power tweeters. Placement of the new tweeters is critical. Unless the tweeters point at the car occupants heads, they are being wasted. This is why many cars mount the tweeters in the roof pillars.
Old Aug 5, 2001 | 06:03 PM
Turbo5's Avatar
Turbo5
Thanks 99HT. I got it. I appreciate the info.
Turbo5
To Install Tweeters
