Sponsored by: Innova
rearview wiring c4
Old Jan 1, 2006 | 08:14 PM
CNTDRV55's Avatar
CNTDRV55
Default rearview wiring c4
xas
Old Jan 2, 2006 | 08:50 AM
chillcat's Avatar
chillcat
well thats kind of an odd ? to ask, but I guess there would be just 2 ways to do it, first (I doubt your radar wire is long enough to run under the piller post trim ALL the way down under the dash and out to the accessory outlet (stealth mode) OR I'm not sure if the voltage running the rearview mirror is 13v, but you might be able to take off the pillar trim and splice into the hotwire going to rearview mirror (that opperates the courtesy light) or you run your own hotwire under the dash all the way up the trim panes to the mirror and splice the radar into that (course you might need to cut off the end plug on radar wire)
