Sponsored by: Innova
Adapters
Old Jan 2, 2006 | 11:35 PM
bobbss's Avatar
bobbss
Default Adapters
I went to Audio Express today and the guy there told me they could only put a sub in my c5 if I keep the stock head unit.He said all of the ones they have done in the past the adapters have burnt up in a short time,some only lasted a month.Has anyone else heard this?Anybody having any trouble?Anybody having good luck doing this?Thanks!
Old Jan 2, 2006 | 11:53 PM
scott_fx's Avatar
scott_fx
just to get this straight, i assume you want to add a sub and get an aftermarket h/u but keep the rest of the bose speakers?
Old Jan 3, 2006 | 09:01 AM
bobbss's Avatar
bobbss
No,I want to keep the stock h/u and at least put a sub in but was also considering to change all the speakers out.
Old Jan 3, 2006 | 09:17 AM
SIICK Blue 02's Avatar
SIICK Blue 02
Default Just did it...
I was told a couple different things from a couple installers...
I went with a Stock HU, JL Clean Sweep, JL 10'' Sub, JL 6.5 Door speakers and left the rear's alone.
It sounds amazing and the Clean Sweep will let you add an Ipod hook-up and it drastically improves the quality of the NOISE.
Old Jan 3, 2006 | 11:11 AM
bobbss's Avatar
bobbss
Thanks!Do I understand right,the JL Clean Sweep is what your using to adapt the stock h/u to the speakers?Have you heard of them going out?
Old Jan 3, 2006 | 11:49 AM
bobbss's Avatar
bobbss
Also I did go to Custom Sounds yesterday too,they want to sell me JL system close to what you have and I'm considering it.The guy at Audio Express recomended that I use 2 8" subs instead of a 10" because of the type of music I listen to which is mostly classic rock and some oldies.What does anyone think about that?
Old Jan 3, 2006 | 01:45 PM
SIICK Blue 02
Default System
The JL clean sweep is used to run after market speakers off the stock head unit and it works great. I have not heard of the Clean Sweep breaking down--- it is a great piece to add to your system.
I would suggest you get the JL 10W3 from www.woofersetc.com and the sub enclosure from www.proboxrocks.com (Search on Ebay $110.00 + shipping) The sound is so crisp and clean you will love it.
I did ALOT of research on the equipment and this is the best way to go, and it sounds fantastic.
Old Jan 3, 2006 | 02:37 PM
bobbss's Avatar
bobbss
Thanks!I know it cost more but did you check out the box JL makes for the C5?Looks pretty good.
Old Jan 3, 2006 | 02:53 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
PAC makes an adapter you can use that is alot less then the JL Cleansweep that many use as well check out the FAQ
Old Jan 3, 2006 | 04:32 PM
SIICK Blue 02
Default Jl Box
The JL Box is the best, no doubt........ but I have the same speaker and paid 1/2 the price for the whole set up. Took the money I saved and bought a Clean Sweep............. now I can use my Ipod-
Old Jan 3, 2006 | 06:30 PM
Prism911's Avatar
Prism911
I wouldn't touch Audio Express with my worst enemy's 10 foot pole. I had a friend get his 350Z done there and he was not impressed at all.
Figure out what you want and can afford to buy and the forum members can supply you with all you need to know about an install. And you will save lots of $$$ to use for more toys.
Old Jan 4, 2006 | 07:43 PM
bobbss's Avatar
bobbss
Prism911,I'm starting to think that way after looking at what you can buy the stuff for online and what they want.Custom Sounds wants about $1,000.00 more for a system installed (that they recomended) than what I can get it online for.They wanted $2,500.00 for their system.$1,000.00 labor sounds a bit high to me.
To Adapters
