Sponsored by: Innova
Avic-D1 GPS sensor location
Old Jan 15, 2006 | 09:41 PM
drwhitley's Avatar
drwhitley
Default Avic-D1 GPS sensor location
For those of you that have installed this unit, where did you put the GPS antenna? I know some do the rear bumber... is it difficult to wire that far away? What kind of wire did you run and where did you run it? I thought I remembered someone locating it in the dash itself and it working... any ideas?
Thanks!
Matthew
Old Jan 15, 2006 | 11:22 PM
rcs128's Avatar
rcs128
I did mine on the bumper bar. Ran the wire into the tub, along the side (passenger), down to the base of the seat, along the frame rail, up into and across the passenger footwell, and into the center stack. There is plenty of wire on the antenna lead to make the run -- no extending needed. And reception in fine.
Old Jan 16, 2006 | 01:25 AM
scott_fx's Avatar
scott_fx
i just mounted it behind under the dash in my g/f's montero and we never have a problem with sat lock. try that for a while see if it works for you.
Old Jan 16, 2006 | 07:40 AM
Lusky's Avatar
Lusky
mine sits on the dash in the center all the way up front to the windshield.
Lusky
To Avic-D1 GPS sensor location
