Sponsored by: Innova
Valentine One
Old Jan 20, 2006 | 01:41 AM
LS WON's Avatar
LS WON
Default Valentine One
Is it safe to leave the V-1 plugged in the cigarette lighter with V-1 off?
Will it still drain the battery?
Old Jan 20, 2006 | 08:35 AM
knewblewkorvette's Avatar
knewblewkorvette
yes, it is safe (except from theives )
no, it will not drain your battery
PS The V1 comes with a hardwire kit, it is not that hard to install. If you don't feel comfortable doing it, a car stereo shop should charge you about $25 to do it. It gets rid of the ugly (and visible to cops) coiled wire. Another benifet, you will no longer have to turn on/off the unit anymore. It will come on/off with the car
Old Jan 21, 2006 | 02:02 AM
LS WON's Avatar
LS WON
I have the hardwire kit but for now I'm routing the 8 ft. cord from the top of windshield with cord tucked in to interior down and below steering wheel so there is no wire to see but I'm still using the cigarette lighter.
Isn't 25.00 a bit low ?? In California I will probably get charged the hourly rate $100+
Old Jan 21, 2006 | 01:33 PM
knewblewkorvette
I based that on $50 an hour and labor of .5 hours. But you are right, out in Cali they could easily be charging $100 an hour
Old Jan 22, 2006 | 05:13 AM
LS WON's Avatar
LS WON
I was born and raised here in the Kalifonia republic...and it is getting old quick..we pay too much for everything..
Old Jan 27, 2006 | 12:18 AM
TicketBait's Avatar
TicketBait
The stereo shop I am going to tomorrow is charging $75 phr and is alloting two hours for the install
Old Jan 27, 2006 | 01:08 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
id shop around that sounds outrageous to me and idk how it could take a shop 2 hrs ive done cars in 15 min... there are v1 install writeups on the web that are very good search the forum i bet u could tackle this urself
Old Jan 27, 2006 | 01:30 AM
TicketBait's Avatar
TicketBait
OMG
Ok I did some more research, looks like I wont be getting that $150 install,
I read bugmans instructions (wow, they are great) and went to invisicords web site.
I already have thegreatlakes mirror mount.
I may try this myself after I get the teambiker wire harnass from invisicord ($14) or do you think that is something I could get at an auto or hardware store?.
No having to run the wires down to the fuse box
Thanks pentavolvo for suggesting I shop around
Old Jan 28, 2006 | 01:31 AM
LS WON's Avatar
LS WON
Default ok then...
Where is a good spot to mount a mobil scanner in the C-6?
Old Jan 28, 2006 | 02:04 AM
pentavolvo's Avatar
pentavolvo
Ok whenever I do V1's or escorts I always just use a phone cord cut off the end strip the wires figure out what is what and wire it in, seems a hell of alot cheaper to me but thats how I do it. Its easy to hook up and all cars I have done i go to fusebox except C5 i did ignition harness if I recall
Old Jan 28, 2006 | 02:23 AM
LS WON's Avatar
LS WON
Old Jan 28, 2006 | 08:21 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I used the phone cord too ,wired to the mirror ,cost me nothing.
Old Jan 29, 2006 | 01:52 AM
LS WON's Avatar
LS WON
The V-1 has so many features that are so different than other detectors. I guess it is this detector that sets the standards.
To Valentine One
