Sponsored by: Innova
Can you split a single preamp outlet?
Old Feb 11, 2006 | 06:16 PM
LD85's Avatar
LD85
Default Can you split a single preamp outlet?
Can I take a single Pre Amp outlet and run it into a splitter so I can send the signal to the A/B amp input and the C/D amp input?
Old Feb 11, 2006 | 06:19 PM
leolufse's Avatar
leolufse
You can split it if you only have one pre out, but you will half the signal going into each amp. If you are working with two amps, it would be better to keep the full range signal into amp 1, then use amp1 output into amp 2.
Old Feb 11, 2006 | 06:54 PM
LD85's Avatar
LD85
Can I run one signal into the A/B channel then come out of the Pass Out and go into the C/D channel, is this better ?
Old Feb 11, 2006 | 07:33 PM
scott_fx's Avatar
scott_fx
You can use leolufse's method if your amp has preouts. or if you can deal with the sound qaultiy loss of just using a y-rca cable.
best thing to do would be to get an external crossover/line driver like the audiocontrol 24xs. this will take one input and give you two at the correct voltage, fully crossed over.
Old Feb 11, 2006 | 08:03 PM
LD85's Avatar
LD85
I only have 1 amp
Old Feb 11, 2006 | 10:32 PM
SCannon's Avatar
SCannon
Are you splitting off of the Head unit or the Amp? If you need to get a different amp I have a few for sale.
Old Feb 12, 2006 | 02:12 AM
LD85's Avatar
LD85
My head unit has 1 preamp out, and I have an A/B channel input with a pass out, and C/D channel input wiht a pass out.
When I run the Receiver output into the amp input A/B lets say, I only get front sound , when I use C/D input I only geat rear sound
Should I run the input into A/b
then the pass out from A/B into the input for C/D?
Old Feb 12, 2006 | 11:06 AM
leolufse's Avatar
leolufse
It sounds like a 4 channel. You should be able to have all 4 channels drive from a single set of inputs. There may be a setting on the amp that you need to set, or you may need to wire input into lets say A and C. What is the make and model number, you might be able to find the owners manual on line.
Old Feb 12, 2006 | 01:25 PM
scott_fx's Avatar
scott_fx
there may be a switch on the amp that will send the signal to all the chans. but if not, then yes, run the pass out from a/b to c/d
Old Feb 12, 2006 | 04:27 PM
LD85's Avatar
LD85
Thanks guys, obviously there is a problem, I think my amp has finally bit the bullet. My 4/3/2 channel switch has no effect on the signal
I will order a new amp this week, gonna pick up a Alpine MRP-F450 4 Channel Amplifier, 4 x 70
To Can you split a single preamp outlet?
