Sponsored by: Innova
Notch Filter or Dynamat ?
Old Feb 13, 2006 | 09:30 PM
Scott-89's Avatar
Scott-89
Default Notch Filter or Dynamat ?
I am gathering some new stereo equipment to install in my 89. I am just going to add a new head unit and speakers at this point and not adding any amps or subs. I just want decent sound and my old bose system buzzes and whines so much I can't even stand to turn it on.
I have being doing some research and I have read a couple articles that advise putting in a 160hz notch filter for the door speakers. I have also read that you can help/fix this resonance problem with sound deadener.
I am using 6.5 inch speakers in the front and 6x9's in the rear. I am going to run extra wires incase I decide to add an amp and subwoofer later on.
So I guess my question is, do I need to add a filter to the front speakers or would I be better off adding some sound deadening to the doors instead ?
Scott
Old Feb 13, 2006 | 10:08 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Ive done it with neither one, but I generally deaden when possiable... I have never used a notch filter
Old Feb 13, 2006 | 10:27 PM
DPG's Avatar
DPG
St. Jude Donor '06
if your stereo is buzzing, theres something there that you should check out. Check your ground wires and check your plug wires too.
Old Feb 13, 2006 | 10:31 PM
Scott-89's Avatar
Scott-89
I am going to do a tune up as well, new plugs and wires. The old bose speakers sometimes take 15 minutes or so to kick on, I am sure they are shot. I am going to replace them with some Pioneer speakers and Pioneer head unit. I am also running new speaker wires.
Old Feb 13, 2006 | 10:36 PM
pentavolvo's Avatar
pentavolvo
It should sound light years ahead of the bose you will be happy... feel free to ask questions ill be more then willing to help as well as other memebers as well
Old Feb 14, 2006 | 09:56 AM
knewblewkorvette's Avatar
knewblewkorvette
the old notch filter....wow I haven't heard that in awhile. I had a headunit back in the 80's with that button on it. With today's signal processors/equalizers the notch filter is no longer needed as that peak can be attenuated that way.
IMO, definetely do some sound deadnening on the door panels. Here is a link to the stuff I use.
http://www.b-quiet.com/index.html
and yes, as above, you'll be way ahead in SQ/SPL of the Bose even with the Pioneer HU and speakers
Old Feb 14, 2006 | 04:31 PM
Scott-89's Avatar
Scott-89
Thanks for all the info
Old Feb 17, 2006 | 10:55 PM
Scott-89's Avatar
Scott-89
Is there anything special I will need to install 6.5 inch speakers in the door ?
Do you have to gut the box that the old bose speaker/amp is in ?
To Notch Filter or Dynamat ?
