Sponsored by: Innova
keeping bose speakers
Old Feb 16, 2006 | 06:41 PM
CorvetteUSCG's Avatar
CorvetteUSCG
Default keeping bose speakers
anyone got any experience with keeping the bose speakers, using the bose adapter through an aftermarket h/u? wondering if the sound is alright thanks
Old Feb 16, 2006 | 06:54 PM
scott_fx's Avatar
scott_fx
check this out:
http://forums.corvetteforum.com/show....php?t=1308160
Old Feb 16, 2006 | 07:17 PM
CorvetteUSCG
cool thanks man i'll try it, what the hell, see what it sounds like...
BTW: i don't clearly understand why i must run power thru fuse no 22 for power...why not just use the stock 12 V signal? i know the faq says that power is removed by the PCM...any other way to fool it?
Old Feb 16, 2006 | 07:32 PM
scott_fx's Avatar
scott_fx
i dont think so, i think your only option is to pull it from the footwell. its nto that much of a hassle though. i'd say skip the fuse thing and tap the wire instead (the correct wire is in the faq somewhere) htats what i did and it's really simple with one of those wiresplicer things
Old Feb 16, 2006 | 08:09 PM
CorvetteUSCG
ok cool ill just splice it. did you keep it going through a fuse or no?
Old Feb 16, 2006 | 08:15 PM
scott_fx's Avatar
scott_fx
i think the wire is after the stock fuse but just put a small inline fuse to be on the safe side
Old Feb 16, 2006 | 08:37 PM
CorvetteUSCG
so is this correct-
the soundgate adapter is only useful if I plan on running the stock subs. Otherwise, it will not change the sound from the h/u to the speakers at all.
I plan on using my own amp and sub so should i be concerned with those stock subs?
Old Feb 16, 2006 | 08:51 PM
scott_fx's Avatar
scott_fx
are you replacing the door speakers at all? if no, then yes be concerned with the stock subs, they will provide some midbass that will be lacking if you disconnected them. if you are going to replace the entire door speaker and put in your own components then you dont need the adapter.
Old Feb 16, 2006 | 09:01 PM
CorvetteUSCG
roger that, i'll go ahead and order the adapter then thanks for the continued help!
Old Feb 17, 2006 | 09:21 AM
steve haverl's Avatar
steve haverl
I really did not appreciate how bad the Bose speakers suck until I changed mine out (MB Quart) and you would be amazed at the difference in sound quality if/when you change them out.
To keeping bose speakers
