Sponsored by: Innova
need help installing amp!!
Old Feb 17, 2006 | 09:53 AM
smknvette's Avatar
smknvette
Default need help installing amp!!
Hey guys, i have put an amp and two 10's in my 01 vert. I ordered the pac-aoem-vet1 and have everything wired up. My amp has power but here is still no sound coming through the sub's. Is there somthing else I need to do?? Have put many systems in before just never in a corvette. Thanks for the help!!!
Old Feb 17, 2006 | 10:35 AM
DPG's Avatar
DPG
St. Jude Donor '06
here was my problem, did you turn the gain up all the way on the pac adapter. After i did that, it made a world of a difference.
Old Feb 17, 2006 | 11:15 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Ok you said the amp turns on is it powering up or powering up and going into protect mode? Are you sure all your connections are tight behind the deck
Old Feb 17, 2006 | 11:26 AM
smknvette's Avatar
smknvette
I think everything is tight. The light on the side of the amp comes on, when I turn the gains on the pac adapter nothing happens. Factory stuff works like always and sounds correct. All the wires on the speakers are tight, but nothing comes through them. Is there any way to check sound at the speakers??
Old Feb 23, 2006 | 11:07 PM
ILM-Express's Avatar
ILM-Express
MFIC
I'm installing a similar setup next weekend, but single 12
To need help installing amp!!
