Sponsored by: Innova
C6 Door Speaker Wiring
Old Feb 18, 2006 | 04:04 AM
djgcue's Avatar
djgcue
Default C6 Door Speaker Wiring
I'm trying to install my own speaker wires in the C6 doors. Can someone please help explain how to get the wires through the passenger and drive side doors to inside the cabin?
Thanks in advance.
Old Feb 20, 2006 | 05:57 PM
leolufse's Avatar
leolufse
You need to pull off the sill panels. On the drivers side, reach up about where the hood release is. There is about a 4"x4" square rubber/plastic plug. Tug on that and it will pop out.
On the passenger side, there is the same thing, but you need to remove the panel that is under the glove box. It is the black one with the light fixture mounted in it. Held in place by one or two plastic friction connectors.
Old Feb 21, 2006 | 08:28 AM
Steve Germany's Avatar
Steve Germany
I removed the subs and ran a coat hanger to the inside of the cabin, hooked the wires and drew them back.to the door. Simple.
To C6 Door Speaker Wiring
