Sponsored by: Innova
door speakers?
Old Feb 21, 2006 | 06:09 PM
CorvetteUSCG's Avatar
CorvetteUSCG
Default door speakers?
i just got the soundgate adapter, and I am still not too impressed, the lack of noticable highs bugs me. I think Im going to get new speakers. If I do buy new speakers, do i have to rewire the doors? can i just use a regular wiring harness? I know there is a stock amp, but I tried wiring it up without the adapter and it didnt even sound like it was doing anything. anyone got any info
Old Feb 21, 2006 | 10:00 PM
carnutsx2's Avatar
carnutsx2
Default speakers
what year?
Old Feb 21, 2006 | 10:04 PM
CorvetteUSCG
Old Feb 21, 2006 | 11:12 PM
scott_fx's Avatar
scott_fx
you'll need to run new wire to get a full signal, it's really easy in this car though
Old Feb 22, 2006 | 11:52 AM
Prism911's Avatar
Prism911
One good reason to run new wire is so you can leave the stock wire as-is and thus easily revert everything back to stock if/when you decide to move to a different car.
Old Feb 22, 2006 | 12:07 PM
DPG's Avatar
DPG
St. Jude Donor '06
good point, this way you wont have to buy everything back to go back to stock. This is why i like the plug n play stuff, with little to no splicing needed. It costs a few bucks more, but this way its real easy to revert back to stock.
Old Feb 22, 2006 | 02:03 PM
CorvetteUSCG
cool ill get my buddies to help me run new wire. Unsure of what speakers to get, I'm thinkin about alpine's or infinity's. you all heard good things?
Old Feb 22, 2006 | 02:24 PM
scott_fx's Avatar
scott_fx
get cdt's they arent that expensive and sound great.
Old Feb 22, 2006 | 03:36 PM
CorvetteUSCG
before i order anything, is it alright if i get infinty kappa's 2 way in the front and another 2 way component in the rear?
I am correct with buying 3 1/2" and 6 1/2" right?
Old Feb 22, 2006 | 04:38 PM
SpeedUp's Avatar
SpeedUp
that statement disturbs me i JUST bought the gmcrv1, and was going to put it in this saturday.
I was reading over the soundgate instructions, did you have to move the black wire like shown in step 3 under the "Note:" section ?
Old Feb 22, 2006 | 04:53 PM
CorvetteUSCG
yes i did, still nothing. i am going to try to return it to soundgate, they probably wont take it. i thought that it would sound a lot better, but it still sounds like poo even with the front speakers, they sound weak
Old Feb 22, 2006 | 04:56 PM
DPG's Avatar
DPG
St. Jude Donor '06
thats why i went with the PAC. its a direct plug. just had to splice one wire to get the remote power. Not sure how the soundgate works though.
Old Feb 22, 2006 | 05:03 PM
SpeedUp's Avatar
SpeedUp
That sucks. Did your new HU harness have a wire for illumination? My alpine has a orange wire labeled 'illum' and a blue/white labeled 'remote turn-on' the gmcrv1 doesnt have leads for these. It does have a blue wire labeled power antenna.
Now the part that really pisses me off. I returned the PAC os-1 to get the soundgate! Another reason I returned it was the os-1 had the onstar stuff. Is the only PAC part I need is the OEM-1 ?
Old Feb 22, 2006 | 05:21 PM
CorvetteUSCG
your exactly right. mine doesnt have an illumination wire either, really pisses me off.
i'm going with new speakers.
Old Feb 22, 2006 | 05:26 PM
SpeedUp's Avatar
SpeedUp
One other thing. did you get the GM Chimes piece? some people have told me that I need the chimes adapter, and some said no.. do you still have chimes without it?
So, without the orange ilum wire, what happens? The HU lights do not dim when you turn the head lights on ?
Old Feb 22, 2006 | 05:30 PM
fej's Avatar
fej
The stock system does not have a dedicated "tweeter" and without cranking the treble up on the HU your highs really suffer. I have no firsthand experience with the adaptors so I hope you get some sound improvement.
As for as component sets in the rear I personally would not recommend tweeters in the rear ad their sound is so directional you will pull a lot of your front stage image to the rear and most likely keep that weird "sweet spot" just over the right shoulder like the stock system has. But to each their own
Fej
Old Feb 22, 2006 | 06:24 PM
Prism911's Avatar
Prism911
Unless you are doing some custom fabrication, I wouldn''t know where in the rear you could mount the tweeters from a component set. There is just a spot for 6.5 or 5.25 depending on your car, and not a very deep spot on the driver's side at that. I put some JLAudio coaxials back there.
To door speakers?
