Sponsored by: Innova
C5 - Sub Box Question
Old Feb 22, 2006 | 11:53 AM
Halfway's Avatar
Halfway
St. Jude Donor '06
Default C5 - Sub Box Question
This is probably a dumb question and I probably haven't thought this through all the way.
But---
Couldn't you just have a single board cut to fit the center compartment, with the sub mounted on that and use the existing compartment as the "box" If you could seal the top onto it, wouldn't it be a legit enclosure?
Please tell me why this is not a good idea, before I do something stupid!!
Thanks guys!
Old Feb 22, 2006 | 12:05 PM
DPG's Avatar
DPG
St. Jude Donor '06
you can but i think it would be harder to seal that way. How would you seal it to the carpet? That would be my only concern.
Old Feb 22, 2006 | 12:28 PM
scott_fx's Avatar
scott_fx
to seal it properly you'd have to drill a bunch of holes into the car so you could screw the board down. plus if it's not completely flat you'll have to find ways to fill the gaps
Old Feb 22, 2006 | 12:50 PM
teddyca's Avatar
teddyca
I agree with all, and to mention, why not just build a small box that is easily removable and no holes required. I have 1 10" in there and it sounds amazing. Hell you can go my route and build it about 1" from the top and put a bueaty board that covers it all up.
Old Feb 22, 2006 | 01:28 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
Thanks guys...Like I said, I posted this without really thinking it through. I guess sealing it would be the toughest thing. Trying to find a way to get a 12" in there without spending the $200 for the flush mount box from sub thump.
Thanks again guys
Old Feb 22, 2006 | 01:51 PM
DPG's Avatar
DPG
St. Jude Donor '06
seriously the covers that go over the subs are usless. They just rattle like crazy. your better off just goin with a box that has more cubic air than going for the flush mount IMO. I tired to put my center cover over the sub and it just rattled loose. when its not in use its great but, when does that happen.
Old Feb 22, 2006 | 02:24 PM
scott_fx's Avatar
scott_fx
Thanks again guys
i have some subbox plans from another member. email me your address and i'll send them to you.
Old Feb 22, 2006 | 03:52 PM
teddyca's Avatar
teddyca
Mine actually was screwed off to the box and worked fine. I bought the car with it. I did take it off because the excursion from the sub with my type of music had the surround hitting the cover.
Old Feb 22, 2006 | 04:59 PM
DPG's Avatar
DPG
St. Jude Donor '06
exactly, it fits perfect so long as you dont play music, then once the tunes start the cover gets bumped off by the subs. good quality and fit from subthump though
Old Feb 22, 2006 | 10:29 PM
J's Toy's Avatar
J's Toy
Could you email me those plans?
jjspruell@hotmail.com
To C5 - Sub Box Question
