Sponsored by: Innova
Pre out question
Old Mar 4, 2006 | 08:48 PM
LD85's Avatar
LD85
Default Pre out question
On my single output Pioneer 1-1/2 din receiver, the output says
Pre Out "R"
My guess is that this is just a pre out for the "rear" signal only, no front signal
Does this sound right?
I just bought a new PHOENIX GOLD Octane-R 4.0:2 2 Channel Amp 2 X 75 watt, to power my 2 front 6.5 " Infinity Speakers,
and I will use my 2 X 150 Jensen watt amp (temporarily) to power two 8JBL GTO 8" subs
The next purchase should be a new 200 x 2 or there abouts and then 2 new subs,,,, little by little,,,
TIA
Old Mar 4, 2006 | 10:05 PM
fej's Avatar
fej
This is just a guess but most likely the "r" output does stand for rear and is most likely non-fade (does not fade with fader changes on the deck to front/rear). This is the output you would want to use for your sub.
Fej
Old Mar 5, 2006 | 06:20 AM
LD85's Avatar
LD85
Fej
Thanks, I have arranged and rearranged my connects etc and I only get all rear or all front.
The new receiver will fix this, it has 2 Pre Outs.
Old Mar 5, 2006 | 03:49 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You could just hook it up to the rear channel, then power your rear speakers from the stereo amp front.
Or get an amp that accepts hilevel outputs.
To Pre out question
