Decided to replace the Nav system in my 2006. What a pain, trying to figure out if I have a amp or not. No service manuals for 2006 yet. Does anyone know which wire I need for kicking on the amp. The AVIC-D2 says to connect to the system control teminal of the power amp. The pin breakout (car harness) that I've been looking at has a B3 Ant enable signal. In back of my AVIC I have two wires marked auto ant remote control and one that has system remote control both are blue of course. Any Idea which one???
I'm using the Metra GMO5-04, Had it hooked up yesterday but no sound. According to the instructions I should have cycled power on and off but I didn't. Didn't see that part, so I pulled the system back out.
The Metra OS-04 ? just ckn -
Ok-- soundz like you have the right part.. you might have to do a modification --
the last C6 I did .... I had to change the way the it was wired ...
The Remote output from the module .. goes to turn on the OEM amp - It shuts off ...
Sooo - I had to tie all of them together ... it worked perfectly ...
Hope this helps ... Also - Ck the voltage on that B3 white wire... should be 12v
yea that's what I meant, been beating on this for a few days and going brain dead. When you said tie then together do you mean both blue and blu and white wires?
you want to use the Blue/White - from the Pioneer ...
