Sponsored by: Innova
New Issue
Old Mar 15, 2006 | 04:24 PM
KDuniverse's Avatar
KDuniverse
Default New Issue
Ok, so I got my car back from the body shop friday. Since then, the driver side crackles like hell, and eventually goes in and out. Any idea what to look for? I've done the usual look for loose wires. The connections at the speakers are soldered.
Also, from time to time, the amp will cut out for a few seconds then come back. Any ideas? Is that usually a ground issue?
Old Mar 15, 2006 | 04:31 PM
DPG's Avatar
DPG
St. Jude Donor '06
do you have the stock stereo and equipment or aftermarket equipment?
Old Mar 15, 2006 | 04:32 PM
KDuniverse's Avatar
KDuniverse
JL 300/2
JL 250/1
CDT ES520's
Alpine 9815
It's been in for about 3 years now.
Old Mar 15, 2006 | 04:38 PM
scott_fx's Avatar
scott_fx
i wonder if the insultation has worn through and you are getting some grounding on your speaker wires
just a stab in the dark though.
can you run some new speaker wire directly from the amp to the speaker to test it out?
Old Mar 15, 2006 | 05:31 PM
KDuniverse's Avatar
KDuniverse
I can definitely try. I was so careful on how and where I ran all the wires. Everything was taped up, and routed out of the way, and was secure.
Old Mar 15, 2006 | 08:07 PM
DPG's Avatar
DPG
St. Jude Donor '06
sure sounds like its grounding out somewhere
Old Mar 18, 2006 | 10:52 AM
KDuniverse's Avatar
KDuniverse
Found out what was wrong. Monster Cable RCA's suck. the fittings that connect to the amp are loose. Almost to the point that they slide off themselves. I tried to crimp them down to make them tighter, but they are brittle and almost break apart. great product.
Old Mar 19, 2006 | 03:48 AM
DPG's Avatar
DPG
St. Jude Donor '06
Sorry to hear that. At least you found the culprit. I'm a big fan of monster. Just not their prices. Check out www.knukonceptz.com for some rca cables. Im very happy with their cable as well. Many here recommend these cables for amp installs.
Old Mar 19, 2006 | 06:16 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
I can honestly say I am less then happy with monster cable especially at the price, the quality just isnt there. I get a huge monster cable discount through work and I still take the KunKonceptz RCAs over the monster
Old Mar 20, 2006 | 07:56 AM
KDuniverse's Avatar
KDuniverse
I'll check those out. thanks
To New Issue
