Sponsored by: Innova
Big 3 Question
Old Mar 15, 2006 | 05:59 PM
KDuniverse's Avatar
KDuniverse
Default Big 3 Question
I'm looking to do a big 3 in my C4. Can someone give me a breakdown of what this consists of? I've done searches, but I need to be absolutely sure of what I'm doing. Also, in each of these new lines, are there any fuses added? All old is pulled out as well, correct?
Old Mar 16, 2006 | 12:40 PM
KDuniverse's Avatar
KDuniverse
TTT, anyone?
Old Mar 17, 2006 | 07:01 AM
KDuniverse's Avatar
KDuniverse
thanks a lot guys.
Old Mar 17, 2006 | 08:23 AM
-=Jeff=-'s Avatar
-=Jeff=-
Originally Posted by KDuniverse
thanks a lot guys.
What exactly is the big 3?
I have heard the term on other stereo boards, but not sure what it means..
Old Mar 17, 2006 | 09:16 AM
DPG's Avatar
DPG
St. Jude Donor '06
I dont know much about the big 3 either. I havent heard of people puting in any extra fuses. Yes I would assume that you would replace the old wiring. Alternator to battery, motor to ground. and whats the other. Did you try the DIY in the tech tips section?
Old Mar 17, 2006 | 09:21 AM
knewblewkorvette's Avatar
knewblewkorvette
here you go
http://www.edesignaudio.com/wire_pro...?productid=242
it is a kit but also states what it is for
Old Mar 17, 2006 | 11:15 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Some people will fuse the alternator to battery lead, its not necessary but when you think about it its not exactly a bad idea either
Old Mar 17, 2006 | 09:56 PM
GeorgeB's Avatar
GeorgeB
http://forums.corvetteforum.com/show...99&forum_id=20
Old Mar 18, 2006 | 10:56 AM
KDuniverse's Avatar
KDuniverse
ok. i'm tackling this project real soon. I'm guessing no one in a C4 has done this?
Also, 4Awg is enough? I've seen a lot of people going with 0. How do I know which I should go with?
What type of connectors, battery terminals, etc did you guys go with? I'm getting ready to order a few Stinger products. Anyone else?
Old Mar 18, 2006 | 11:21 AM
BRICHC4's Avatar
BRICHC4
I also don't know what the big three is, but I have 4 awg cables and a optima yellow top, pushing probably 800w rms and everything works fine. All you need is one large fuse within 6 in of the battery probably like a 150, and the only other time you will need a fuse is if you are using a distribution block. Enough wire to reach everything easily. And the amount of terminals you need at each end. I don't know how much or what you are doing so that is pretty much a basic.
Old Mar 18, 2006 | 06:35 PM
fej's Avatar
fej
I agree with Birch, but with one amendment you should generally fuse near the amp as well as within 6" of the battery connection just to further protect the amplifier. Usually a 40-50amp fuse here will do the job and it is not absolutely necessary but highly recommended. Fused distribution blocks originated for this reason
Fej
Old Mar 19, 2006 | 03:38 AM
DPG's Avatar
DPG
St. Jude Donor '06
See if Stinger makes a kit for the big 3 that will include all the terminations needed.
To Big 3 Question
