Sponsored by: Innova
C5 New H/U vs Speakers
Old Mar 24, 2006 | 04:39 PM
Devilhawk's Avatar
Devilhawk
2nd Gear
Default C5 New H/U vs Speakers?
Hi folks, Im replacing my Bose H/U with Aftermarket, Ive got the Pac ROEM Ive got the DIN Kit and Antenna Adapter, My question is with the Front and rear speakers. First it appears that with the Pac Kit it says I will loose the sound from my 3.5s and if so do I need to scrap the PAc and go the rout of amp and replace bose all together? Is there a way to have both the ROEM and 3.5s without adding an amp(maybe just H/U power) Ideally I wanted to Just replace the 3.5s and use the ROEM and later get a Sub setup for the back. I assume with the ROEM kit that the rear are using H/U power just like the Bose did
Also Speaker question( Ive been out of the game for a long time )
What would you rate the top 5 Brands?
Thanks for the help
Old Mar 24, 2006 | 09:03 PM
valet_devil's Avatar
valet_devil
Look into the Soundgate adapter. Search for the exact model number. It was designed to add an aftermarket h/u while retaining full functions of the weird bose speakers.
Old Mar 24, 2006 | 10:45 PM
scott_fx's Avatar
scott_fx
or oem-vette from pac-audio, i think you just purchased the incorrect harness.
Old Mar 27, 2006 | 12:56 PM
Devilhawk's Avatar
Devilhawk
2nd Gear
Ahhh I got the correct harness just incorrect Info Phewwwww!!!! I thought I was screwed. Ok again I still need to know what brand of Speakers I should be looking at? Alpine, Infinity, Kicker, Sony????? The last time I even looked into audio equipment was one job and 2 kids ago Im clueless on whats top notch now days.
To C5 New H/U vs Speakers
