Sponsored by: Innova
Mini Reversing Camera
Old Mar 25, 2006 | 08:21 AM
DeeGee's Avatar
DeeGee
Default Mini Reversing Camera
I just bought a mini camera to hook up to my Pioneer AVIC system.
I'm about to install it but I have a couple of questions.
Is there a switched power supply at the rear? The only sources I can think are only on when in use (back up lights, lighting circuits)
Whats the drain on a battery? I can't imagine the camera itself use much power. What about the transmitter?
Any thoughts?
Old Mar 25, 2006 | 09:36 AM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
I couldn't fine one whne I did mine so I ended up hooking mine up to the backup light lead. I wish I would have ran a switched power lead instead. Now the camera only comes on when in reverse.
You have to run the RCA wire anyway so I'd run a new lead.
Old Mar 25, 2006 | 10:10 AM
DeeGee's Avatar
DeeGee
The camera I got is wireless so I dont need the A/V lead.
I ran a wire for a fog light so I have the route sorted. I think I may try the battery first and see how long it lasts
Old Mar 25, 2006 | 07:02 PM
DeeGee's Avatar
DeeGee
Well its in.
I hooked up the control unit to an ACC supply. I'm trying the camera on battery for starters. If It lasts a reasonable time I'll leave it at that.
Old Mar 26, 2006 | 10:38 AM
comp's Avatar
comp
Old Mar 26, 2006 | 04:20 PM
DeeGee's Avatar
DeeGee
Originally Posted by DeeGee
Well its in.
Answered that question. The battery lasted 24 hours
Guess the next job is to run a hot wire back there.
Old Mar 26, 2006 | 05:06 PM
rcs128's Avatar
rcs128
When I installed my D1 I ran the extra switched power wire from the pass floorboard fusebox back to the rear for a Sirius tuner that's mounted in the right-hand cubby. I was pretty easy to run it along the passenger side frame rail, up behind the speaker and around to the rear of the car.
Old Mar 26, 2006 | 07:01 PM
14U2ENV's Avatar
14U2ENV
Hungry little sucker!!!
Old Mar 26, 2006 | 07:03 PM
WilliamCall's Avatar
WilliamCall
Any thoughts?
Dee Gee,
I don't suppose your convertible has the factory CD changer in the trunk. I tapped into the switched power and ground leads from my CD changer when I installed my camera. Just a thought.
Old Mar 28, 2006 | 11:44 PM
DeeGee's Avatar
DeeGee
Originally Posted by WilliamCall
Dee Gee,
No unfortunately it doesn't. I guess I need a power wire from the front. Next weekends job sorted out
To Mini Reversing Camera
