Sponsored by: Innova
Help me build an amp rack!
Old Mar 25, 2006 | 12:59 PM
cmb13's Avatar
cmb13
Default Help me build an amp rack!
I'd like to build an amp rack for my new custom stereo. Can you help? Ok, here are the facts:
1. It will have 2 amps; JL 250/1 and 300/2
2. It will have 2 crossovers - one for each side of the front speakers (2 way speakers)
3. It is going to go under the convertible top
4. The car is an '05 Corvette convertible
5. I'd like to have a carpeted top and front; I can leave the back (front of the car) open, as it will be invisible from the trunk and from the passenger compartment.
So, my questions are, how do I build this? Do I use MDF? Do I need a bottom, or just lay it on the carpet? I imagine I should place MDF on the carpet, build walls, build a top, and cut out holes in the top for the amps to show through.
If so, how do I mount the sides? L-brakcets? How thick should the MDF pieces be? Do I need to screw the bottom into the frame of the car?
How do I construct this so I can open it if I need to access the amps?
Finally, do I need a fan? Or, if it is open in back (the part facing the interior passenger component, which can't be seen anyway, is a fan unnecessary?
Lots of questions - thanks!!!
Old Mar 25, 2006 | 09:34 PM
cmb13's Avatar
cmb13
Also, I read an awesome amp rack article, but had a few questions:
How do I mound the facade / trim plate on the base of the amp rack? In other words, how do I get it, say 1 inch above the rack, and secure it to the rack? Do I use dowels or something? Small wood blocks that get nailed to the rack and that the facade nails on to?
Also, how do I get exposure to the wiring once this in place?
Old Mar 25, 2006 | 11:50 PM
scott_fx's Avatar
scott_fx
Originally Posted by cmb13
Do I use MDF?
yes
yes, you should build a bottom to bolt everything down
i'd say use at least 1/2" if not 3/4" mdf drill and screw the boards together. the sides arent going to be very high so the screws and the other sides will be enough for support
not really, you can friction fit it in the vert. thats what is holding mine in place.
make the walls out of two pieces of mdf. make the inner piece so it is about 1/2 or 3/4" shorter then the outer wall. this will give you a nice lip where you can mount the facade to. you wont need anything to hold it in place that way
fans will never hurt you can display the fan into the facade like i did or hide it.
Old Mar 26, 2006 | 03:28 PM
cmb13's Avatar
cmb13
Thanks for the assistance. I'm short on vertical space, so I may go 1/2 inch. Someone mentioned using plywood - why is MDF better?
Also, you mentioned making the inner walls 1/2 inch shorter. Can you help me out here? What do you mean by inner and outer walls?
Thanks again!
Old Mar 26, 2006 | 07:05 PM
scott_fx's Avatar
scott_fx
instead of using a router use tow pieces of wood back to back. one being shorter then the other (vertically) this will give you a 'shelf' or 'step' that the facade will rest on. if you aren't set on going with the facade look, check out my install and you could mimic that with out having to worry about the height issues as much.
aslo, i guess you could use 1/8 birch plywood as your base as well, it's just not as easy to screw into, you'll need to bolt everything down.
Old Mar 26, 2006 | 10:38 PM
cmb13's Avatar
cmb13
Thanks - I think I'll go with 1/2" MDF for the base. Now, for the facade that gets carpeted, probably 1/4" MDF? This will be for the top and the front facade.
Old Mar 28, 2006 | 02:56 AM
comp's Avatar
comp
Old Mar 30, 2006 | 12:15 PM
cmb13's Avatar
cmb13
I got my wood yesterday - 1/2" for the base, 1/4" for the facade. 1x2 for the sides and a center support as well. Now to assemble, spray it black, and install components.
To Help me build an amp rack!
