It is a common myth that the Valentine One is large and heavy. As hard as it might be to believe, the Valentine One, 16.2 cu. in., is smaller than the Escort X50, 18.95 cu. in., and the Bel RX65, 16.32 cu. in. The Valentine One is wider because it has 2 antennas and not 1 like every other radar detector, but it is shorter and not as tall which gives you more mounting options.
As far as weight goes,
Valentine One -> 181.5g (6.40 ounces)
Escort 8500 X50 -> 253.7g (8.95 ounces)
Beltronics RX65 Pro -> 236.6g (8.35 ounces)
Beltronics STi Driver -> 291.6g ( 10.29 ounces)
As you can see, the 8500 X50 is the largest in size and the Bel STi Driver is the heaviest. The Valentine One is the smallest and lightest radar detector of the Top 4 radar detectors made today.
I own the V1 and I always thought it was large and heavy. Apparently looks can be deceiving
How many times have I seen this thread topic over the last month???
TOO MANY!!
Boy, if that is not the truth. Do the ol' search button under V1
