Sponsored by: Innova
speakers install
Old Apr 12, 2006 | 12:21 AM
AndrewNguyen's Avatar
AndrewNguyen
Default speakers install
is there such a thing as plug in speakers which dont require any wiring just a switch of the old and new, because when it comes stereos i dont know anything
thanks
Old Apr 12, 2006 | 12:57 AM
fej's Avatar
fej
You can replace the stock 3.5" twiddlers in the bose system with a drop in 3.5" mid/tweet combo speaker from Infinity or JBL ( I think) or Alpine (I think). You can also replace the rear speakers with 5.25" speakers or 6.5" speakers without changing anything. Just plug and play stuff. Worth it on the front 3.5's IMO.
If you want to do more it involves adaptors and amps and $$$
Fej
Old Apr 12, 2006 | 11:24 AM
Sully1882's Avatar
Sully1882
Default wiring
i just did this last night, I cut the stock plug off of the stock bose speaker and soldered it onto the new speakers and then plugged them back up and put everything back together. Whether or not there is an easier plug and play setup I don't know but this was very easy. Hope that helps.
Thomas
Old Apr 12, 2006 | 11:34 AM
DPG's Avatar
DPG
St. Jude Donor '06
Thomas
Did you get any noticable improvement from your upgrades?
Old Apr 13, 2006 | 03:57 AM
Boeingman's Avatar
Boeingman
Thomas
Can you review what exactly you removed and replaced please?
Old Apr 13, 2006 | 11:02 AM
Bgreenard's Avatar
Bgreenard
Go Fast
I changed the front 3.5 with infinity and the rear with Alpine a few weeks ago. I'm glad I made switch the improvement is very noticeable. Cost me $120 for the entire setup from crutchfield.
B
Old Apr 13, 2006 | 04:23 PM
cmb13's Avatar
cmb13
You will have to clip the wires and add some type of connector, possibly, and strip the wires. Very easy to do; takes about 35 seconds / wire. Can you do that?
It cannot be done with the self-powered subs, though.
Old Apr 15, 2006 | 10:26 PM
astvega's Avatar
astvega
do you have to take the door panel off to get to the 3 1/2"
speakers?
Old Apr 16, 2006 | 12:36 AM
fej's Avatar
fej
Yes, unless you unclip the bottom of the door panel without removing the whole thing and unbend the taps that hold the bose grill in place. Would not recommend that route.
Check out www.vetteessentials.com for the removing the door panel guide. Really not hard once you know what steps to do it in. Need a couple torx bits to do it as well.
Fej
To speakers install
