Sponsored by: Innova
Electrical Wiring Question
Old Apr 13, 2006 | 11:10 PM
jnjmarshall's Avatar
jnjmarshall
Default Electrical Wiring Question
I am re-wiring my C5 for a new stereo/speaker system. In the door and the rear, can I just use basic electrical tape to wrap the wires for protection?
Old Apr 14, 2006 | 12:18 AM
scott_fx's Avatar
scott_fx
are you soldering the wires? if so i'd get shrink tubing, much cleaner and isnt all sticky I only use tape as a last resort.
Old Apr 14, 2006 | 06:38 PM
bullets1's Avatar
bullets1
If not soldering, wire caps and then tape. The tape will likely degrade due to heat from sun exposure.
Old Apr 14, 2006 | 07:06 PM
scott_fx's Avatar
scott_fx
i am going to have to say no on the wirecaps. butt-connectors are much better.
Old Apr 14, 2006 | 07:08 PM
fej's Avatar
fej
Fej
Old Apr 15, 2006 | 02:20 AM
jnjmarshall
I am planning on soldering, so I will go with shrink tub, but in the doors, all the wires are wrapped with purplish tape completely. Do I have to do that for all the speaker wires I run to the doors?
Old Apr 15, 2006 | 11:18 AM
wiz1500's Avatar
wiz1500
Thats used to keep all the wires in a nice little harness for install. I use zip ties.. as far as the conection goes you want to solder everything and pull and tug when you are done make sure each and every connection is secure...Don't go with the thought that it's good enough...Make sure it is right before you move on this will save you a drama latter...ask me how I no????
Old Apr 18, 2006 | 02:26 AM
scott_fx's Avatar
scott_fx
this is a little soldering how to for those of you interested:
http://www.able-audio.com/tutorials/howtosolder.php
To Electrical Wiring Question
