Sponsored by: Innova
Help!!!
Old Apr 19, 2006 | 01:06 PM
62Frameoff's Avatar
62Frameoff
Default Help!!!
Trying to remove the Bose rear speakers in a C6 vert, have the panel out, but cannot unplug the speaker wires from the speakers. My last resort is to just cut the wires, but I know their must be a simple way to unplug these connectors, but I cannot figure it out. Any help would be appreciated.
Old Apr 19, 2006 | 01:29 PM
DPG's Avatar
DPG
St. Jude Donor '06
there should be a clip on the connector lift up on the tab and pull apart
Old Apr 19, 2006 | 03:38 PM
62Frameoff's Avatar
62Frameoff
Default Thanks
I found the clip, it is under the connector, but with the 3-4 inches of wire slack, it was impossible to see it or turn the panel enough to get to the clip. I finally had to use a long screw to reach around and blindly hit the clip to pull the connector off. One thing for sure, this connector was NEVER going to fall off!!
Old Apr 19, 2006 | 03:56 PM
DPG's Avatar
DPG
St. Jude Donor '06
it always seems that the shorter or less room you have to get to a connector, the harder it is to get the connector off. Glad you didnt have to resort to cutting.
To Help!!!
