Sponsored by: Innova
Laser Jammer?
Old Apr 26, 2006 | 11:39 PM
ChickenHawk's Avatar
ChickenHawk
Default Laser Jammer?
OK so I haven't started a car without first plugging in my V1 for ten years ...actually they're all hard wired now. So now I see Laser jammers have graduated to the level that Cincinatti Microwave (Escort) is offering one ...which to me lends credibility ....and something called the "Blinder" seems to be even better.
Has anyone had any experience with any Laser Jammers? From what I've seen they run around $500 installed which I will gladly pay if they work, I don't expect perfection, but something that got 3 out of 4 successful interventions would really get my attention. What can you tell me guys?
Old Apr 26, 2006 | 11:56 PM
achilds's Avatar
achilds
They are illegal is some states, CA for instance. Check out some of the radar test websites for their evals on the effectiveness of laser jammers. The products seem to work, but you sure don't get much warning time. Most of the highway patrol guys are using K or Ka bands.
Old Apr 27, 2006 | 03:25 AM
shopdog's Avatar
shopdog
I've been using the ZR-3 Shifter for a while. I had it on my 350Z and now it is on my Corvette. It works. My neighbor is a cop. We ran some tests. With the Shifter off, he can get a reading just about as soon as the car comes into sight, more than 1000 feet away. With the Shfiter on, he can't get a reading until I'm less than 100 feet away.
The cops in the Atlanta metro area are heavily into laser. I get tagged 4 or 5 times a week. Now in a car without the Shifters, the laser detector in the 8500 will give a short blip to tell you you've been tagged. It only takes 50 milliseconds to get a valid speed reading with the laser units the local cops are using, so they don't have to hold the laser on you very long. But with the Shifter running, they typically hold on me for 10-15 seconds trying to get a reading. Those seconds could allow you to really reel in the speed if you are going fast.
Now I usually don't break the speed limit by much, so there are only a few times when I'm really worried about getting a ticket. But it is reassuring to hear that long laser tag as I trundle by a cop. That's telling me the system is still working.
Old Apr 27, 2006 | 03:34 AM
meldog21's Avatar
meldog21
Originally Posted by shopdog
I've been using the ZR-3 Shifter for a while. I had it on my 350Z and now it is on my Corvette. It works. My neighbor is a cop. We ran some tests. With the Shifter off, he can get a reading just about as soon as the car comes into sight, more than 1000 feet away. With the Shfiter on, he can't get a reading until I'm less than 100 feet away. ...
I did the same test with a buddy here. Normally I could lock a speed on cars anywhere from 500-1300 feet(the laser gun reads feet with the speed). I couldn't get a reading on his car until he was about 50 feet or less away. Now I know, anyone I can't get a reading on is running a jammer, which in CA is a separate infraction, CVC 28150(a) Jamming devices for police radar or laser.
Ok, let the name calling and ridiculous self gratifying abuse begin.
Dog
Old Apr 27, 2006 | 11:20 AM
djgcue's Avatar
djgcue
Dog
Is the infraction for jamming radar in CA more serious than a speeding infraction assuming the speed wasn't wreckless?
Old Apr 27, 2006 | 12:21 PM
meldog21's Avatar
meldog21
It's just the same as any other infraction as far as I know. I don't have a bail schedule(ticket price list) for it so I don't know how much it would cost.
Dog
Old Apr 27, 2006 | 03:23 PM
not08crmanymore's Avatar
not08crmanymore
Default jam this..
why bother if the v1 works as well ????and those arrows!!
Old Apr 27, 2006 | 06:32 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Because when the V1 gives you a laser warning its too late you have been tagged. The only thing the arrows will tell you is where the cop that IS giving you a ticket came from
Old Apr 28, 2006 | 12:16 PM
not08crmanymore
Default laser
so,who makes the zr3 and where is it sold?although i never had an issue w/the v1.
Old Apr 28, 2006 | 12:35 PM
wt2ga's Avatar
wt2ga
Default The ZR3 Works as Advertised
Old Apr 28, 2006 | 12:44 PM
wt2ga's Avatar
wt2ga
Originally Posted by wt2ga
Check with Tuan Lee Supporting Vendor
Old Apr 28, 2006 | 05:37 PM
RockyL32's Avatar
RockyL32
The only issue with the V1 is that it detects laser only. Laser takes less than 1 second from off to get your speed, V1 will detect this and alert within ( I believe) .3 seconds this leaves you only at best .7 seconds to: notice, react, check speed, and slow down. It is pretty much commen knowledge that without a Laser jammer of some sort if you hear your detector alert for laser the oficer will have your speed before you can do anything about it. If your Laser detector goes off and you dont get a ticket you most probably were not going to get one wether you had a dector or not.
Old Apr 28, 2006 | 08:25 PM
ayeroff's Avatar
ayeroff
I've been running the ZR-3 laser shifter for a while now in combination with my Escort Passport 8500 X50 (I don't think its compatible with non Escort brands). I've run the same "tests" as described above with a friend of mine on the local police dept. The shifter definitly works as advertised, and has saved my butt on more than a few occasions.
However, any officer that routinely uses laser also knows that if his laser gun isn't locking on and giving a speed reading after more than a few seconds, then the driver must be using a shifter. If its a state, where shifters are illegal, then here comes a ticket. If they are legal, he can still pull you over based on visual speed determination.
So, the trick is to use the shifter as its intended... As soon as the system alerts you to laser, immediately SLOW DOWN AND then quickly TURN OFF the shifter (just push the button). That way, the officer gets a speed reading on his laser gun after only a few seconds, and hopefully that few seconds has given you time to slow down to the speed limit (or at least significantly slower than you were going before the laser alert went off).
No detector or laser shifter or any other device is going to make your car "stealth". But I love my X50 and ZR3 and can't recommend them enough.
One last point: While a few states (Virginia, California, and most recently Illinois) have outlawed LASER shifters... it is illegal in ALL STATES to use any type of RADAR jammer (plus, I've read that the ones on the "market" don't really work anyways).
Old Apr 29, 2006 | 10:36 AM
not08crmanymore
Default zr3
how much is that thing??
Old Apr 29, 2006 | 12:26 PM
ayeroff's Avatar
ayeroff
I think I paid $499 plus $125 for installation (which also included hardwiring the ZR3 and my Escort Passport 8500 X50).
Old Apr 29, 2006 | 01:26 PM
wt2ga's Avatar
wt2ga
They go for a little less than $350 on eBay (self install)
Old May 18, 2006 | 12:48 PM
99SilverVert's Avatar
99SilverVert
I think if I dont find any concrete evidence that the K40 Defuser works Im ripping it out of my car.
..After seeing this video is seems useless..
http://www.jasonsvideoproductions.com/k40defuser.wmv
To Laser Jammer?
