Sponsored by: Innova
Subwoofer question
Old May 5, 2006 | 09:58 PM
webdzynes's Avatar
webdzynes
Default Subwoofer question
If a sub box is built to spec, will it sound better, worse or no different if I also put in a fair amount of fiber-fill? I know thats generally done when the box is smaller than spec calls for but what about when the box is right?
Old May 6, 2006 | 02:23 AM
fej's Avatar
fej
If it is built to the proper air space for the sub (IE recommended enclosure) you can alter the sound of the bass output a bit by adding polyfill to trick the sub into thinking it is in a bigger box that it is. Basically making it a bit more "boomy" while loosing a bit of the tightness of the bass reproduction. (would take a fair amount of poly to see a difference from my experience) Sometimes a bit of polyfill is used to keep the sound wave from the rear of the sub bouncing directly back into the cone and causing some cancellation/distortion.
Worth experimenting with a bit for sure. Worst case scenario you just pull the polyfill out if you do not like the sound change. You might just like the sound better
Fej
Old May 6, 2006 | 09:48 AM
DPG's Avatar
DPG
St. Jude Donor '06
i still have to play around with that stuff and my subs fej. im slacking
Old May 6, 2006 | 03:17 PM
vetterlatethannever's Avatar
vetterlatethannever
with fej. The change in sound might be favorable, depends on the listener.
Old May 6, 2006 | 09:18 PM
webdzynes's Avatar
webdzynes
sorry - whats "fej"?
Old May 6, 2006 | 10:29 PM
fej's Avatar
fej
That would be me. Posting name.
Fej
Old May 7, 2006 | 04:16 PM
vetterlatethannever
Old May 8, 2006 | 09:49 AM
DPG's Avatar
DPG
St. Jude Donor '06
fej i hear is running for first lady
Old May 8, 2006 | 07:16 PM
scott_fx's Avatar
scott_fx
my mom always told me: "don't be a fej"
Old May 8, 2006 | 10:15 PM
fej's Avatar
fej
Is it me or did you choose "senior geek" for your board sub name? And you are going to hate on me?
Fej
Old May 8, 2006 | 10:21 PM
scott_fx's Avatar
scott_fx
Fej
fej, please refrain from hijacking this thread. This thread has nothing to do with me (just you)
Old May 9, 2006 | 08:51 AM
Duramax Dave's Avatar
Duramax Dave
Now that's funny....
So what does a "first lady" on a Vette audio forum do?
Old May 9, 2006 | 11:40 AM
DPG's Avatar
DPG
St. Jude Donor '06
she tends to senior geeks every need
To Subwoofer question
