Sponsored by: Innova
Radio Bezel Modification Question
Old May 10, 2006 | 08:05 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Radio Bezel Modification Question
I am goign to modify my Radio bezel in my 89. I will be using a 1996 bezel. Keep in mind I have a 1991 interior.
ANyway I need permanently add strength to the back of the panel in a couple spots before cutting the panel, what stuff can I get that will harden like the panel itself, that it pliable to work with while applying?
Old May 10, 2006 | 01:30 PM
scott_fx's Avatar
scott_fx
can you make braces out of strips of abs and use the sludge method to fuse them together?
Old May 10, 2006 | 03:45 PM
-=Jeff=-'s Avatar
-=Jeff=-
Sure, but what is the Sludge method?
Old May 10, 2006 | 04:45 PM
scott_fx's Avatar
scott_fx
abs (i.e. pipe) melted in m.e.k. and use that as a glue. it will melt the bezel a bit and 'weld' the two pieces together. better then using any epoxy.
Old May 13, 2006 | 10:22 PM
-=Jeff=-'s Avatar
-=Jeff=-
and m.e.k. is?
Sorry for all the questions
Old May 13, 2006 | 11:28 PM
rcs128's Avatar
rcs128
I used an ABS epoxy (bought at Home Depot) for building up areas when i did the console on my C5. It's VERY strong and easy to work with. Build up the areas in layers. And plan on sanding a lot to get to the final desired shape. You could use strips of basla to build up/shape/stregnthen the console as you build it.
here's a link to my install: http://forums.corvetteforum.com/show...t=another+avic
Old May 14, 2006 | 02:06 PM
-=Jeff=-'s Avatar
-=Jeff=-
Well this will be on the back of bezel, so i should not need to do too much shaping and sanding, it is for strength.
Old May 14, 2006 | 02:43 PM
DPG's Avatar
DPG
St. Jude Donor '06
show us some pics as you are doing this. I want to get into the bezel mods sometime this year. With all this rain lately, looks like we can spend a lot of time working on the cars instead of driving them
Old May 14, 2006 | 03:26 PM
scott_fx's Avatar
scott_fx
m.e.k. is Methyl Ethyl Ketone. just a solvent that you can find in any paint department
To Radio Bezel Modification Question
