Sponsored by: Innova
changed my mind
Old May 11, 2006 | 05:57 PM
dolf's Avatar
dolf
Default changed my mind
ok well i was going to do a full system including 3 wasy, amp, and sub. but now im thinking i wont like the extra weight. i think im just going to stick with the head unit and 2 way front and maybe rear fill. the head unit is an alpine iva-d310. it put out 50w max. what are some good choices for speakers that will still sound good at low power? i really like dls speakers so if you could suggest something from their line, if not what would you do. i mostly listen to techno and rock. car is an 02 zo6
Old May 11, 2006 | 06:15 PM
scott_fx's Avatar
scott_fx
i wouldnt power components off of deck power, just not enough power there. you're looking at probably 18-20 wrms which will only be good enough for an efficient coaxial.
how about trying an amp and a 3 way component in the doors. maybe a 7" 4" and tweet? then get a small amp (i just got my zapco 500.1 in today and the thing is tiny!)
and i'd probably forget about the rears.
Old May 11, 2006 | 07:21 PM
DPG's Avatar
DPG
St. Jude Donor '06
you can always pull your sub box out if your gonna go to an event. Or just go on a diet and make up for the extra equipment. They are making amp smaller these days that are just as powerful. Also they are making speakers that are a lot more effiecient that dont require as much power to drive them
Old May 11, 2006 | 07:38 PM
scott_fx's Avatar
scott_fx
check out this thread as well
http://forums.corvetteforum.com/show....php?t=1388408
Old May 11, 2006 | 07:47 PM
dolf's Avatar
dolf
ha ha diet.. thats never gonna happen. im a powerlifter and get about 5000+ cals a day. what i was thinking of doing was using an amp but a small powerfull one to run the front stage only. im not a bass junkie anyways. so heres the revised system.
alpine iva-d310
dls ra20 130x2 at 4 ohm
dls iridim 6.3 3 way components
should still sound great and add very little weight. the amp only weighs 8 pounds. what do you think?
Old May 11, 2006 | 08:54 PM
scott_fx's Avatar
scott_fx
i'd say add some sound deadening to the doors and you'd have a nice sounding system.
To changed my mind
