Sponsored by: Innova
some tuning help please....
Old May 25, 2006 | 10:19 PM
DPG's Avatar
DPG
St. Jude Donor '06
Default some tuning help please....
Hey stereo gurus. Im starting to play around with my headunit and becoming familiar with all the gizmos on it.
Just for a quick rundown as to what im working with here:
Headunit: eclipse cd5000
Front: CDT CL-61A 2ways
No rears
Subs: 2 10s image dynamics
Amp:PG octane R 8.0.4
I have the tweeter crossover set at -3db on the crossover itself. The amp freq is set at 80hz for front and rear(sub).
Now here are some base settings that i will need from you guys. Do I keep the amp settings at what they are? Or do I need to change something? On the headunit, what should my crossover point be? right now its 80hz with a 18db slope. whatever that means Also, how should i have the EQ set on the headunit as well. There are 7 EQ adjustments. Thanks for the help
Dave
Old May 26, 2006 | 12:05 AM
DPG's Avatar
DPG
St. Jude Donor '06
oh and just messing around right now. what should i set the non fade to? Normal or Reverse?
Old May 26, 2006 | 03:13 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Non fade is set to normal (revers means ur subs are invert mounted or wired retartedly). As far as the crossover points IMO 80Hz is a great point to cross a system at. You can turn them off at the amp but you have to make sure its working on the deck then, remeber I dont know that deck that well haha. Because if for some reason it gets turned off on the deck you will have highs goin to ur sub and stuff. Personally I would leave it at 80 on the amp and the deck and just play with the EQ curves. We really need to get that tuning mic in there.
So I take it -3db sounds a bit nicer on the ears then 0db. All and all how are you likeing the speakers? Did you ahve to bring your gains up at all?
Old May 26, 2006 | 09:09 AM
DPG's Avatar
DPG
St. Jude Donor '06
no gain adjustments needed. I just need to play with the eq's and what not. The power is there just needs some fin-ess
To some tuning help please....
