Sponsored by: Innova
C4 has Amp+Sub+Box= Advice needed
Old Jun 5, 2006 | 09:07 AM
GS348's Avatar
GS348
Default C4 has Amp+Sub+Box= Advice needed
I recently purchased one of the stealth boxes that goes behind the passenger compartment as well as, an amp and 10in. sub. For those that do your own installs, where should I start? Where are the RCA's or do I need an adapter prior to install? Any advice would be greatly appreciated. BTW, I am using the stock Bose head unit. Thanks, Chris
Old Jun 5, 2006 | 09:31 AM
RFDrpm's Avatar
RFDrpm
To use the stock BLOSE im pretty sure your gonna need an adapter. Not 100% on that so dont quote me. Best place to start would probally be wiring the amp, have you ever done an install before?
Old Jun 5, 2006 | 10:05 AM
GS348's Avatar
GS348
I figured that I would need some sort of adapter as well. And yes, I've installed about 4 complete systems similar to this one, but this would be a first attempt on a corvette. Thanks for the heads up.....chris
Old Jun 5, 2006 | 11:04 AM
lytmup's Avatar
lytmup
Yeah, Im pretty sure that you need a line level converter to work that external amp with a Bose system.
I would check with Soundgate (www.soundgate.com) to see what they have/recommend.
RFDrpm's Avatar
RFDrpm
Corvettes arent all that different, except that the reciver box is seperate from the in dash unit. Good luck, and dont hesitate to ask.
Old Jun 5, 2006 | 07:39 PM
bogus's Avatar
bogus
Take a few minutes and scan the C4 Audio FAQ...
Old Jun 6, 2006 | 05:23 AM
GS348's Avatar
GS348
thanks for the input guys
To C4 has Amp+Sub+Box= Advice needed
