Sponsored by: Innova
Upgrading stock stereo in C4
Old Jun 6, 2006 | 06:01 PM
MrNuke's Avatar
MrNuke
Default Upgrading stock stereo in C4
If I use an aftermarket headunit's pre-amp outputs instead of the amplified plugs, would I be able to use the stock BOSE system's setup without rewiring everything?
Thanks in advance.
GB
Old Jun 6, 2006 | 06:13 PM
red_johnny's Avatar
red_johnny
Just a question for you. Why would you want to keep the bose amp? The only benefit that I can see is that its already wired up for you, other than that I would replace it all. You can get some nice stock size speakers for under $100 and a decent amp for about $150 so depending on what kind of deck your going with you can really get away with a good sounding system for fairly cheap
BTW I dont know the answear to your question....sorry.
Old Jun 6, 2006 | 06:42 PM
MrNuke's Avatar
MrNuke
Eventually I am going to rewire the car, but for now I don't want to spend the money nor the time to do it RIGHT..
The stock setup sounds damn good for now, just the headunit's cd player aint working and I miss my MP3's
Old Jun 6, 2006 | 07:00 PM
red_johnny's Avatar
red_johnny
Ok, it was just a suggestion. Good luck!
Old Jun 6, 2006 | 10:32 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Yes, you can buy one at Crutchfield. Read the C4 sticky at the top of the page.
Old Jun 7, 2006 | 09:56 PM
MrNuke's Avatar
MrNuke
I Know I can buy an adaptor but that's NOT what I asked..
Old Jun 8, 2006 | 02:08 AM
RandyJ75's Avatar
RandyJ75
Thanks in advance.
GB
Ok, sorry, didn't read they post correctly; thats a good question. Andy, any ideas? I'am not sure if the preamp outputs would have enought current for the Bose amps. You would may be better off with adtapter.
Randy
Old Jun 8, 2006 | 03:04 PM
bogus's Avatar
bogus
Not that I am aware of...
all the adaptors I am familer with would be the ones that allow you to remove the blose speakers and run an amp...
another though, would be something like the JL Audio Clean Sweep.
Old Jun 16, 2006 | 10:02 PM
Brendan's Avatar
Brendan
Cruising
I am looking to do the same. Have you found any info? Ecklers has a JVC head unit for Bose systems but they want $500 for it. I can't tell what model it is.
Brendan
Old Jun 16, 2006 | 10:16 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
I've heard good things about doctordons.com, he can rebuild your head unit and upgrade your cd to play mp3's. check him out
Old Jun 16, 2006 | 10:24 PM
Red Runner's Avatar
Red Runner
Cruise-In I Veteran
No you cannot use the pre-amp out to drive the bose amps. You will need to purchase an adapter to complete the circuit. There are two types that I am aware of. One takes the amp output of the head unit and filters/transforms the signal to be usable at the bose amp. Generally the maximum output (watts) that these types of adapters can handle is about 80 watts. The other type uses the pre-amp outputs and conditions that signal for the bose amp. This on the surface would seem the better solution for keeping the bose system up with an aftermarket head unit. I would think it would generate less noise at the bose amp. I just purchased one of the line level adapter from CarDomain.com.
Old Jun 16, 2006 | 10:45 PM
C4boy's Avatar
C4boy
Yes, but only with an adapter.
I used 2 of these. Head preamp out
http://www.logjamelectronics.com/piepdcloc.html
To Upgrading stock stereo in C4
