Has anyone found good locations to mount (or try out) tweeters for decent sound/ imaging?
Assuming the Woofer in a component set is in the frame rail (OEM Location)
Any other spots for the Woofer/Mid in a component set?
when I had my active 3 way, I had my 8" midbass and 2" soft dome midrange in the kickpanel and I mounted the tweeters in the A-pillar...had a pretty level center stage right around my my dash...i found if you mount a tweeter low in a C4 you risk blocking it with your leg loosing quite a bit of output and moving the center stage to the passenger side...
Was that set-up in a C4? I would love to see pictures of the 8 mounted in the front
