Sponsored by: Innova
90' C4 speaker wiring
Old Jun 18, 2006 | 02:16 PM
ajorda14's Avatar
ajorda14
Navigator
Default 90' C4 speaker wiring
hey i pulled all the bose stuff out and have my pioneer headunit wired up.
im replacing the speakers with 5 1/4 in front and 6x9 sony 3ways in the back.
Can I just hook the speakers up to the existing connections, or do i have to bypass the little bose amps in the enclosures?
Old Jun 18, 2006 | 02:58 PM
techguy's Avatar
techguy
Need to bypass the amps -
There are 4 wires there --
If memory serves me correctly ..
They are -
RED = Power
BLACK = Ground
GREEN =Signal in
GRAY = Signal in
You can just take the inputs and cut them off - then extend them to your new speakers - then the radio will power the speakers ..
No need to re wire the car -
Good Luck
Old Jun 18, 2006 | 03:02 PM
ajorda14's Avatar
ajorda14
Navigator
thanks for that info, i put those bose amps where they belong, in the garbage!
Old Jun 18, 2006 | 09:32 PM
techguy's Avatar
techguy
Welcome ....
Old Jun 18, 2006 | 09:38 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
let us know how it turned out and what you think maybe some pics as well
Old Jun 18, 2006 | 11:43 PM
bogus's Avatar
bogus
do yourself a favour and run new wire. the gm wire is gnarly junk. Get a 50' roll of Monster 16 gauge speaker wire and be done with it.
Old Jun 19, 2006 | 12:07 AM
Demonic85's Avatar
Demonic85
I bought a 40 foot roll of 18 gauge speaker wire, but after hearing that, i'm not sure I want to use the new wire. I could spend all day rewiring the stupid car... or just cut a few wires.
Old Jun 19, 2006 | 01:35 AM
pentavolvo's Avatar
pentavolvo
just rewire its not that bad
Old Jun 19, 2006 | 08:27 AM
techguy's Avatar
techguy
just an FYI -
If all you are doing is using the radio for power to the new speakers ...
Really no need to replace all the wire - There is no audible difference.
If you are looking for performace and are adding some Hi-end Speakers with an Amp... then sure re wire it -
Old Jun 21, 2006 | 04:52 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Or go to home depot and get 50' of the 14 gauge speaker wire. Worked for me
To 90' C4 speaker wiring
