Sponsored by: Innova
XM Antenna-C4 Mount Location ??
Old Jun 20, 2006 | 07:40 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default XM Antenna-C4 Mount Location ??
I just bought all the crap to make my XM ready head unit actually ready
Where are you C4 owners mounting the antenna. I would like to avoid the outside if possible.
Thanks for your input
Old Jun 20, 2006 | 07:46 PM
bogus's Avatar
bogus
well... where you are, I donno how strong the signal will be, and I don't foresee your area getting ground repeaters... so...
I put mine on the painted panel a top the glass hatch, it opens with the hatch.
Looks fine...
I used 3M double stick tape to anchor it down.
Old Jun 20, 2006 | 08:46 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
I put mine on the metal braket inboard of the surge tank, under,yes, under the hood, and ran the wire along & tie wrapped to the hood release cable to the drivers side, once there, between the battery and firewall there is a bundle of wires that go's thru a grommet in the firewall and into the cockpit under the dash. I checked the siginal strength and get 4 to 5 bars. Works good for me
To XM Antenna-C4 Mount Location ??
