Sponsored by: Innova
98 Vert. Power antenna wire????
Old Jun 21, 2006 | 08:28 PM
jers98vet's Avatar
jers98vet
Default 98 Vert. Power antenna wire????
I'm finally finishing up my new stereo install and don't know which wire operates the power antenna. I've checked out the wiring diagram on the sticky but still cannot figure out which one.
TIA, Jer.
Old Jun 21, 2006 | 10:15 PM
scott_fx's Avatar
scott_fx
hmm, i wish i could help you with this one but i don't have am/fm in my car so i never researched it.
ttt for ya
Old Jun 22, 2006 | 03:08 AM
Demonic85's Avatar
Demonic85
The wire for the power antenna should be the dark green on the #3 F pin. This is assuming its a 32 pin factory GM harness.
Old Jun 22, 2006 | 06:38 AM
jers98vet's Avatar
jers98vet
Thanks, I'll try using that one after work today.
Old Jun 26, 2006 | 12:58 AM
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
Here is a picture of the harness... looking at the harness from this view, he is speaking of the green wire, 3rd over from the driver's side in the black plug...
You can test this wire with a voltmeter. It should get 12VDC when you flip the source button on your deck from CD to FM. It should lose it when power button is turned off, or source is switched.
Hope this helps!!
Old Jun 26, 2006 | 06:24 PM
jers98vet's Avatar
jers98vet
Yes , that is the correct wire. Thanks to all for the help.
Jer.
Old Jun 27, 2006 | 12:55 AM
Audio Dave's Avatar
0Audio Dave
Former Vendor
Cool, glad that worked for you...
Old Jun 27, 2006 | 01:08 AM
Demonic85's Avatar
Demonic85
If you ever need help with wiring diagrams, check out this page.
http://www.corvetteradios.com./Page.html
No actual pictures, but the diagrams are very helpful.
To 98 Vert. Power antenna wire????
