Sponsored by: Innova
2004 C5 Battery Power
Old Jul 4, 2006 | 10:46 AM
debmwb's Avatar
debmwb
Default 2004 C5 Battery Power
Those of you with 2004 C5's that have the different battery cables...How did you attach your power wiring for your amps (pics please)?
Old Jul 4, 2006 | 05:24 PM
Xtreme5053's Avatar
Xtreme5053
Just different battery terminals....I have a different battery as well though...
http://kinetikaudio.com/hc1800.asp
Old Jul 4, 2006 | 06:46 PM
fej's Avatar
fej
I have a red top Optima with dual posts and I have my positive cable on the top post for my stereo gear (with new terminal from Knuconceptz). I have not had time for my big 3 upgrade but will be adding my other terminal and using the top negative post for the ground improvements. Normal car connections are via factory terminals at the side post location.
Fej
Old Jul 5, 2006 | 11:39 PM
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
If you are keeping the stock battery, but hooking up an amp to it, you can use a part by Stinger of AAMP of America called a SGMBatt. It is a battery post adapter that allows you to hook up your amp power cable to it. Is this what you are needing? It will work with any sidemount post battery as well...
Old Jul 6, 2006 | 09:27 AM
knewblewkorvette's Avatar
knewblewkorvette
Here's mine.
Old Jul 7, 2006 | 11:36 PM
debmwb's Avatar
debmwb
So did you just cut off the original terminals?
Old Jul 7, 2006 | 11:43 PM
Xtreme5053's Avatar
Xtreme5053
The battery I have in there has two top posts. The wire connectors you see there just clamp onto them. Looks like the same thing with the Optima in the post above yours.
Old Jul 8, 2006 | 11:45 AM
debmwb's Avatar
debmwb
Okay, so you did not modify the original pos and neg terminals for the car? The one's on top of your battery are just for the audio?
Old Jul 8, 2006 | 09:14 PM
knewblewkorvette
My top terminals are just for the stereo (0-guage wire) and the side terminals are used for the factory wiring.
Old Jul 10, 2006 | 12:11 AM
debmwb's Avatar
debmwb
That is a difference with the '04 C5, they changed the battery cables. This is why I'm asking the question. My '04 has battery cables that attach to the top posts. I'm trying to figure out how to connect the audio cables without changing my battery. If my battery was going south, I'd replace it with an optima and put the cables on the top posts and the audio on the side terminals.
Old Jul 10, 2006 | 12:49 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Sorry I dont remeber what the battery looks like on an 04, can you post a pic and I can help you out
pentavolvo's Avatar
pentavolvo
Old Jul 11, 2006 | 08:53 PM
debmwb's Avatar
debmwb
I will post a pic this weekend after I get back from travel.
Old Jul 16, 2006 | 04:48 PM
debmwb's Avatar
debmwb
okay...here are some pictures of the connections to my '04 Coupe.
and a close-up of the terminal...
See...this is my dilemma. They are not regular terminals by any stretch of the imagination! Obviously if I replace the battery for say an Optima with both top and side terminals I have it made. I don't know how to fix what I have without cutting the ends off and changing the terminals.
Old Jul 16, 2006 | 06:39 PM
wiz1500's Avatar
wiz1500
If you take the end of the terminal where the wire comes in and straighten it out you should be good to go......I had to cute mying off.
Two things please don't make fun of the dust and I no the screw on the + side is not stainless. (yet)
Old Jul 17, 2006 | 08:18 PM
knewblewkorvette
Hey wiz,
You need to dust off that battery. While your at it, you should replace that bolt with a SS one
Old Jul 17, 2006 | 11:17 PM
wiz1500's Avatar
wiz1500
Originally Posted by knewblewkorvette
Hey wiz,
There's a SMART ONE in every croud...... (usually it's me)
Thanks for the advise......
To 2004 C5 Battery Power
Old Jul 18, 2006 | 01:09 AM
Chief777's Avatar
Chief777
St. Jude Donor '15
Here's mine.
Probably a noob question, but what's the small red and black lines for? Also, what the advantage of running the ground back to the battery?
Old Jul 18, 2006 | 11:05 AM
wiz1500's Avatar
wiz1500
Let me be the first to take a guss...........I say there for a trickle charger.... .....
Old Jul 18, 2006 | 12:33 PM
DPG's Avatar
DPG
St. Jude Donor '06
yup thats what my little black and red wires are for. trickle charger is great.
