Sponsored by: Innova
audio
Old Jul 18, 2006 | 08:25 PM
5pinball's Avatar
5pinball
Default audio
how do you post a new topic in audio section although from what i saw of it its not limited to vette audio
Old Jul 18, 2006 | 08:55 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
It's the same as any other section.
It's supposed to be limited to vette audio, but there aren't too many moderators here.
Old Jul 18, 2006 | 09:04 PM
scott_fx's Avatar
scott_fx
uhm hold on....you just posted a new topic.....uhm...i'm so confused
just do what you did when you posted this thread but include your question or topic of discussion?
Old Jul 18, 2006 | 09:24 PM
5pinball's Avatar
5pinball
i posted in c4 general clicked on post reply or new thread neither of which i found on audio my question on audio i want to put 2 bose spkrs in dashpad and remote amps under dash somewhere and add spkr relay or tap into existing relay it will give me a total of 6 spkrs in an 88 cpe has anyone done this before is it feasable
Old Jul 18, 2006 | 09:46 PM
scott_fx's Avatar
scott_fx
i'm not sure what you mean by 'speaker relay' could you explain that a bit more.
oh and this is how you make a new post (still confused...did this get moved from the c4 forum?):
http://forums.corvetteforum.com/newt...newthread&f=20
Old Jul 18, 2006 | 09:58 PM
5pinball's Avatar
5pinball
yes it got moved for get spkr relay if its confuseing
Old Jul 18, 2006 | 10:58 PM
RFDrpm's Avatar
RFDrpm
Im confused also, what relay are you talking about.
If you are just trying to put in another set of speakers its as sipmple as splicing wires???????
Old Jul 18, 2006 | 11:01 PM
vetterlatethannever's Avatar
vetterlatethannever
Old Jul 19, 2006 | 10:13 AM
knewblewkorvette's Avatar
knewblewkorvette
You mean we are supposed to use the Audio Forum just to talk about just audio? That's just crazy
What's next...the Audio Forum having a Mod?
Maybe we could use a "First Lady" :o
Old Jul 20, 2006 | 11:21 AM
5pinball's Avatar
5pinball
84to 89 has a relay to turn on spkr amps dont know about my 93 as i havent found a fsm on ebay cheap enough yet only question now is should iadd another relay to the 2new dash spkrs or will existing relay handle additional amps please no smartass comments about my typeing already have had that crap from 2 jerks from calif and 1 from canada
Old Jul 20, 2006 | 12:42 PM
bogus's Avatar
bogus
5pinball... I must be one of those jerks from California. Allow me to continue.
you still need to be introduced to our friends the Punctuation Marks! Please, lemme introduce them to you! The period - "." He is a good one... tells us when a sentence, and a thought, end.
The Comma - ","! Another winner in my book, allows for a clarification of a thought mid way through a sentence!
And please, if you are a foreign national with problems with the English language, speak up... otherwise, we will pick on your unmercifully. Clear questions help get clear answers. Your typing skills are not the issue, asking clear questions is the issue. Reread and edit the post before it gets saved.
Ok... with that said.
Adding speakers to the C4 Bose systems just isn't going to happen. The Bose amps are very proprietary and as such, are not just available. you are not going to be installing any aftermarket components in there and get them to work with the factory bose. It just won't happen.
If you want to install speakers up there, may I suggest doing this as part of a full scale audio upgrade? Remove the bose completely and go totally aftermarket! You should be able to install a nice set of midranges and a tweeter up there, and them install a big ole 6" midbass into the door. If you are REALLY clever, I bet an 8" could be massaged into the early C4 door. It's something I am debating.
Old Jul 20, 2006 | 03:45 PM
RFDrpm's Avatar
RFDrpm
I gotta see this one, come on Andy do it.... Ill send you my door panels now...
Old Jul 20, 2006 | 03:48 PM
bogus's Avatar
bogus
I am thinking it is doable... I am going to mess with the wifes 87, so if it works, I will let you know.
As for the 92, I have successfully installed 4" mids into the carpeted area. boy, that sounds nice.
To audio
