ARG!! Radio wiring HELL!!
Now for the IRRITATING part, NONE OF THE COLORS MATCH!! And I cant find a singe dang chart that shows the bose color match!!
It already looks like I am going to have to cut the factory harnesses, and on top of that I dont even know what color goes to what!!! OR how to integrate the converter!!
I have a 1995 corvette... any help would be very very much appreciated
it is either in the left rear bin (ABS bin) or in the dash. Lets hope it's in the storage bin.
The head unit on these things are dummies. regardless of being bose or delco. the output is controlled by the receiver module.
find the reciever, you find manna.
My Pioneer front and rear outputs are female rca.. am I going to have to cut off the RCA connectors and wire them to the converter, then wire the converter to the amp?
What exactly do I plug the new wiring harness into? I cant figure out where the heck it goes.
I am new to car stereo install, please be patient with me
I unearthed the amp and I figured out I can connect the harness to the amp harnesses, but I dont know what to wire THAT to! And what about the converter.. its supposed to connect to the amp AND the reciever somehow too, does it go inbetween the harness and the reciever?
.. I am completely lost.
See, I got the harness from out of the amp to the GM02, but no idea what to do with it.. and doesnt it need to be connected to the amp?
You have a new Pioneer head unit... and you currently have Bose.
Are you trying to interface the Pioneer to the Bose? Unless that's the one special Pioneer that is sold by Ecklers, it ain't happening.
Sorry.
The only things those harness are good for is power, ground and memory. You will need to get aftermarket speakers.
Have you been over to the Audio/Electronics area? There is a C4 Audio FAQ that might be of some help.
This thread should be there, too, cause there are more of us there to help you through this process.
So far the concensus has been in order to retain the factory speakers/amp, I needed the wiring harness for the power, and the LOC for the speakers. I am just confused on where exactly they are supposed to be connected.
I know In order to supply all the power i can go through the harness, then run wire up to the HU. So I have a rough idea of what needs to be done... I could connect the power through the GM02 harness and run it into the HU taking care of all that right? But I cant figure out where the LOC goes in. The SVEN4 instructions actually give a diagram of where it needs to be connected, but the harness it instructs you to connect to fit right into the harness, and thats where Im really getting confused.
The HU I can power up, no prob. Its connecting the speakers and working with the amp that is creating my problem.
and you are flirting with disaster... I don't like the idea of driving the bose amps with anything but an acceptable bose level input.
this would require an adaptor to take the RCA leads and convert them to a compatible signal. otherwise, it will sound like ****.
and it will more than likely sound like **** anyway... I have heard these types of fixes, and the sound quality is no better than original, you are not changing much, really... the SQ is still dependant on the output.
Infact, the last one I heard had amps and stuff, and it sounded muddy as hell.
